Zum Hauptinhalt wechseln
Die DJI Mavic Pro ist eine kompakte, faltbare Drohne, die Videos in 4K Qualität aufzeichnet. Sie kam im November 2016 auf den Markt. Modellnummer: M1P Modellnummer der Fernbedienung: GL200A
20 Fragen Alle anzeigen
Why does my drone get a Jello-effect?
Why does my drone get a Jello-effect ?
I have tried to utdate everything, but nothing seems to make it better.
Blury picture on the phone while filming..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
That must be from vibration. Most drones that don't have a damper have this problem, but that shouldn't happen with this one. If your under warranty, send it in to DJI so they can have a look at it.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
@pccheese ,Cepeders, Blurry picture on the phone while filming, try a different device as maybe your phone is not linking properly. If under warranty consider using it for replacement/refund/repair. Check to see if the camera/lens is loose on the drone and vibrating around. You may have already done so, do a search( dji mavic pro drone blurry picture) as there is numerous post/articles/forums that discuss this issue. Find below a disassembly guide to get you inside the check for loose wires/components/etc. that could cause an issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
DJI Mavic Pro Teardown
Bewertung 2
Antwort hinzufügen
Cepeders wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,779
