Zum Hauptinhalt wechseln
Veröffentlich im Mai 2018. Modellnummer XT1922.
19 Fragen Alle anzeigen
Moto G6 Play replacement screen 1mm too short
I know this is going to sound weird but I ordered a screen from 2 different suppliers for a Moto G6 Play and both replacement screens are 1mm too short. Everything lines up at the top and the shape is perfect but there is a gap at the bottom. The flex cables work and are a perfect match to the original. Anybody else have this issue?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 6
3 Kommentare
Yes got the same problem, I recommend buying with frame assembly
von
Our shops have ran into this issue as well. We now buy it with the frame only.
von
Unable to find XT1922-9 replacement lcd w/ frame...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hey Jestin, I have since discovered there are 7 variations of the G6 Play. Some of them use a 150mm screen and some use a 152mm screen.
If the supplier doesn't specify, you will most likely get a 150mm.
I found an eBay seller that lets you pick which one you want and it worked great.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
I had the same issue today with the screen i received from a local supplier today. Everything works on it, its just short.
I end up replacing the screen anyway.
von
iFixit sells genuine Motrola parts. I would sugget you search on iFixit for availability of the specific moto part you need in order to ensure a proper fit. The genuine parts are going to be a lot more reliable!
Bewertung 0
Antwort hinzufügen
brentongraber wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,224
