Zum Hauptinhalt wechseln
Device and repair information for the 60" LED HD TV by Samsung released in 2013, model number UN60FH6003FXZA.
20 Fragen Alle anzeigen
Samsung TV will not turn on
Hello. First of all, thank you for taking the time to consider my issue. I have a Samsung UN46D6003SFXZA that will not turn on. When I plug it into the wall the red power light will blink 6 times. When I unplug it from the wall the red power light will double-blink 5 times.
I understand Samsung had an issue with using faulty capacitors. Do you think that could be it? Below is a picture of the power board. What is the white caulk/adhesive?
Thanks again for your time….
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hello Patrick, the chalk substance you see is just to keep parts from vibrating especially line filters and transformers, it is something Manufactures use to secure parts that will potentially vibrate and cause noise.
As to your no power issue there could be a few reasons, you could have a bad power/inverter board according to your picture the power board has to functions to power on the system and power on the LED lamps.
I don’t know your level of electronics troubleshooting, but the first thing you need to check is the supply voltages coming from the larger cable running to the Main board, the value of the voltages of each pin is indicated on the board in small print. But considering you have a red standby light on tells me your standby voltage is there. First try unplugging the TV and hold in the power button for 20 secs while the set is unplugged from AC. This is called hard reset. If that doesn’t work try turning on the set unplug the large cable coming for the power supply to the main board, the panel should light up if it does then replace the PS/Inverter board. The power supply supplies 5V constantly to the main board even when the tv is off. When u pushe power on button the main board sends 3.3Volts back to the power supply teling it turn on the rest of the unit. Also try disconnecting the Led connector at the top of the board this will be the smaller cable with wires running into the Panel and try turning on tv.
Hope this answer gives you some indication of where to start..
LT…
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
LT, I plugged the TV into the outlet to begin following your steps and I noticed the red power light stayed solid. In fact, the TV appears to be working now and I have no idea why. Perhaps having it unplugged over night had something to do with it?
I'm actually a little disappointed. My son and I were going to pick up a voltmeter and make this a project of ours. I guess we will need to break something else!
Thank you for your time.
Pat
von
Antwort hinzufügen
Patrick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 2,507
