Zum Hauptinhalt wechseln
Repair information for the Dell Inspiron 15 7560. This is a 15 inch laptop that is part of the Inspiron 7000 series.
2 Fragen Alle anzeigen
Potentially ominous problem discovered under hood of Inspiron 7570
I just removed the casing for a first time battery change after 18 months since I bought this device, and discovered that the foil on the hard drive is split, with a connector peeking out. In all other images/videos for this model, the foil is intact and no connector is visible. Can anyone explain what might have happened here? Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You bought a machine that just came with an SSD and Dell included the cable and drive caddy so one can be added later. You didn’t get screws, but 2.5” drive screws aren’t hard to get.
Think of it like this: Your machine didn’t come with a drive, but it was provisioned so you can add one.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
You've really put my mind at rest. Thank you Nick.
von
Antwort hinzufügen
Steve wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 282
