Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
20 Fragen Alle anzeigen
Buzzing noise tied to brightness
I bought one of these used and everything was great. But, after a few days of leaving it plugged in and off, I noticed a crackling sound coming from it. I unplugged it and the noise immediately stopped. When I turned on the computer/display a bit later, the noise was terribly loud and gets louder/softer if I raise/lower the display brightness. Some online research seems to indicate that it has to do with the power supply (I guess this is what happens if there’s no real “off” button). How can I go about replacing the power supply?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
On any lcd/led monitor any buzzing sound linked to brightness intensity, is pretty common to be a hardware issue, maybe a swollen capacitor.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
whitefire45108 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 15
Insgesamt: 477
