Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
Apple LED Cinema Display "27" and Temperature
Hi guys,
I recently bought an Apple LED Cinema display and had some issues with it.
Sometimes, the screen won’t turn on, it will stay black for hours but, the speakers and the USB work fine.
I’ve been trying some tests on it and found that when I sleep with my window open at night, the screen will not turn on for hours when I try to turn on him the morning. But every time I sleep with the window closed, the screen will automatically turn on, and won’t have a black screen.
So my question, is there something linked to the temperature of the room, or the display itself that keep him on black screen?
If yes, is there a piece that I could change to fix this problem?
Ist dies eine gute Frage?
Bewertung 0
8 Kommentare:
What is the system you are using it with? Mac Pro, MacBook Pro or iMac?
von
i am using the display for my Windows 10 computer
von
@bobtaro - Are you able to test the display with a Mac system?
von
@danj no, i don't have any MAC system
von
I think you'll need to find a friend with one to test your display out with.
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Did you update?
About the 27-inch LED Cinema Display Software Update 1.0
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
i don't have a mac, so i can't update it
von
It appears the logic board will need repairs or just replacing it (logic board P/N 661-5544). Given the age of the display, it’s likely a weak cap or cold solder joint is the issue.
See if you can find a set of the LED Cinema Display (27-inch) Schematics & Boardview to help you isolate the area of theologic board that needs service.
Using the Mac you can now check the displays firmware is upto date: LED Cinema Display Software Update 1.1 This addresses a speaker issue it had.
Bewertung 0
Antwort hinzufügen
Filip wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 671
