Zum Hauptinhalt wechseln
{A1706 / EMC 3071}—Veröffentlicht im Juni 2017. Dieses 13" Macbook Pro ist mit Kaby Lake Prozessoren bis zu 3,5 GHz Core i7 mit Turbo Boot bis zu 4,0 GHz ausgestattet.
Part Identification of the IR0 capacitor
Hi,
i just ripped the capacitor in the red circle off, it is the same one as in the green circle.
Can someone tell me, what capacitor this is exactly and - preferrably - where to get one?
I googled some time and wasn’t able to find this part unfortunately.
Update (08/24/2020)
I just learned that this is in fact an inductor…
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
@deichstein - Finding the specs of the inductor will require finding the board number which starts off with 820-????? (a five digit number).
That way we are sure to get the correct value reviewing schematics and boardview drawings.
Then you can look it up at one of the electriconics parts suppliers.
von
Thanks Dan! Could this number be printed on the backside of the board? I couldn't immediately find it on the frontside...
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I found the following datasheet:
https://johansondielectrics.com/download...
Just measure the size of that inductor, and you can find out what part number you need.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
This is what you are after. Component “L7960” (1UH-20%-11A-0.0127OHM) Digikey or mouser should have them in stock if you cannot source from another board.
Bewertung 3
Antwort hinzufügen
Sam Deichstein wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 100
