Zum Hauptinhalt wechseln
Why is my laptop not turning on?
When I plug in the CA adapter, and press the power button, nothing happens. There are no LED lights, the fan does not turn on, no noises from the hard drive, nothing. The AC adapter appears to be good, it gets the required voltage to the motherboard. Voltage checks on the motherboard show CPU 19.5V, power button 3.34. I have tried removing hdd, ram, resetting the bios and checking the CMOS, and each time trying to power the laptop up, still no joy. I do not have the schematic diagram. How do I proceed to fix this problem?
Ist dies eine gute Frage?
Bewertung 0
6 Kommentare
What happened before this problem arose? Was everything working fine?
von
Yes Mike everything was working just fine. Powered down before going to sleep, and then next morning the laptop just failed to turn on. I have noticed though that when I put the battery back on. the charging light comes on.
von
@fordi Yeah check the battery health in ePSA. My old E6540 did something like that when the pack started to wear, but it booted with multiple attempts. My E6440 is fine so far, though - but it's NX31D battery is almost as tired and may do it soon.
F12>Diagnostics.
von
Thank you Nick for your suggestion. However, the challenge is the laptop does not run long enough to get into bios or activate diagnostics via the Fn keys. The screen is blank, no fan spinning, nothing.
von
@fordi
You may have seen this site already with tear down videos:
https://www.parts-people.com/blog/2016/0...
von
1 weiteren Kommentar anzeigen
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
This trick got me two i7-4600U IPS FHD Touch E7440’s for $98/unit* - one sadly needs a screen (bad backlight) and neither sold with a battery, SSD+cable/caddy or RAM (although I did rummage up some 4GB DDR3L modules), so I may not be able to economically repair the bad unit :(. That said, the one with a good LCD is ready as soon as I buy a battery and a HD caddy+cable, and possibly put a matched RAM set in. I’m recycling an SSD from another machine.
*Covid market - even desperate parents didn’t want to touch that gamble for their kids for Zoom school. It's because the possibility of a bad board is very, very real.
Pull the CMOS battery for 1-2 minutes and try to boot without it. If it boots, the CMOS RAM was corrupted. If it doesn’t, confirmed bad motherboard. It’s not like this isn’t known, so I don’t mind revealing it. The issue is some Dell laptops are sensitive to CMOS corruption moreso then others. The E7440 is a 2-in-1 special: it hates booting with CMOS corruption (which isn't entirely uncommon) and it's somewhat voltage sensitive. I suspect your Vostro is in that same group.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Fordi Dhliwayo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 16
Insgesamt: 460
