Zum Hauptinhalt wechseln
The Sony α6500 can be identified by model ILCE-6500. It's a mirrorless, digital E-mount camera with APS-C Sensor. The Sony α6500 was released in November of 2016.
Sony a6400 LCD problem
I couldn’t choose a6400 in the menu and figured the a6500 was the closest.
My issue happened when I was flipping my screen over. It worked fine before flipping, but after flipping it the picture disappeared and all I could see was the faint bright vertical lines, as seen in the photos
When the lens is pointed towards something bright, the monitor gets a slightly brighter silhouette, as seen in picture 2 . The touch-tracking also works, and by looking into the viewfinder, it tracks where I press as well.
It should also be noted that I sent the camera in for repair a few months back, due to a destroyed SD-card slot. Do you think one of the ribbon cables might have come loose after the repair, or is the screen itself broken? There are no visual signs that it should be, but I would like some expert opinions before I open it to check the cables.
Thank you in advance!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
It may be easy to be confused what is the cause, but as the screen seems intact and it happened when you tilted the screen I think it’s more likely to be a flex cable problem. It’s not expensive - try it first. But be VERY careful inside, the clip connector is fragile. Tackle it with a toothpick. And beware FLASH DISCHARGE PADS. Touching them is a little trick to momentarely waste a few hundred bucks killing your camera as I did once. Better never get there.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Kristoffer Svendsen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,112
