Zum Hauptinhalt wechseln
Die Neuauflage von Apples iPad Air Tablet vom März 2019, das mit dem A12 Bionic Prozessor und dem 10,5" Display antritt.
20 Fragen Alle anzeigen
Can someone identify this cable inside ipad air 3?
I am trying to do a screen/lcd replacement on my ipad air 3. I though I did it all correctly and it powers up with perfect screen, but won't respond to touch. I noticed I am missing a cable right next to the battery which is highlighted in green in the attached photo. Can anyone identify what that is?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
thanks so much! So that cable shouldn't affect touch screen? I have no use for sim, so I should be able to use without it?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
hello Jared,
It is a sim reader flex tape with connector.
The lack of touch functionality is usually related to screen damage during lifting / detaching from housing. Sometimes it's just a badly inserted connector into the port (check it necessarily and don't forget about the battery: the old principle of electronics - start with the battery when disconnecting and ending with connecting). Sometimes, unfortunately, damage is caused by unreflective disconnection of connectors from the motherboard and damage to them area.
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
von
yes, you right
von
Do you if it will function with an e-sim despite the connector being broken?
von
Is there not a short flex at the bottom with about 4 solder points that needs transferring? Can cause issues if it's not soldered onto the new screen.
Bewertung 0
1 Kommentar:
what you write about is a magnetic sensor for smart cover / keyboard. Causes the screen to turn off when the flap falls on the screen. The tablet will work without it, but yes, it is good practice to move it to a new screen.
von
Antwort hinzufügen
Jared Cantor wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 114
