Zum Hauptinhalt wechseln
Model number: 20R1000RUS, Released in June 2019
13 Fragen Alle anzeigen
Why does my power button blink 3 times?
i recently found my lost laptop. When i plug in my charger the power button flashes 3 times and then nothing happens from there.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 8
1 Kommentar
I have the same Issue with my Lenovo X1 carbon 6th. When I press the power button nothing happens. But when I plug in the AC cable the light on the back flash tree times. And there is some sound from the processor.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
For others reading this there are two power staus lights.
One is for the AC power located on the back of the computer.
The other one on the top right from the keyboard is the power on light.
Rick have you tried activating the emergency reset button.
This is located on the bottom of the laptop and can be activated by inserting a paperclip in the hole.
Here are the steps:
  1. Unplug power
  2. Find a thin paper clip
  3. Locate the Emergency Reset Hole on your laptop
  4. Press and hold the Reset Hole for ten seconds with the paper clip
  5. Power on
War diese Antwort hilfreich?
Bewertung 13
9 Kommentare:
Hello Mike,
I have the same problem with the same laptop brand.
Lenovo Thinkpad T480. I tried the reset method but nothing changed,
Maybe there is something more i can do to check for the problem.
I will apriciate if u have any other advice.
von
Hi @andreaq,
Some how missed your question.
Here is link to service manual:
https://download.lenovo.com/pccbbs/mobil...
(from page 44) Blinks three times:
• Three Blinks quickly: The computer is entering sleep or hibernation mode.
• Three Blinks slowly: The computer is in sleep mode.
Page 35 explains sleep and hibernation modes.
von
couldn't find the reset button. i just reseat the battery and it was successfully powered on.
von
Yes I found the reset hole in the back of laptop. I inserted the push pin, reset it and it worked for me. Thank you Rick for the post.
von
Thanks a lot, it saved my day as well.
von
4 weitere Kommentare anzeigen
Remove/disconnect both batteries. Remove RAM. Disconnect "button battery".
Wait more than 1min.
Reconnect all.
It worked for me.
Bewertung 0
2 Kommentare:
Same symptoms, but pushing (with paperclip) and holding the reset button on the bottom of my Lenovo T16 fixed mine.
von
Emergency reset on bottom of the laptop will only work for about 3 times. So make backups and check for warranty. The second time this happens bring in for repair and demand them to fully boot regularly for about 4 or 5 times after reset.
von
Antwort hinzufügen
Rick smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 165
Letzte 7 Tage: 1,098
Letzte 30 Tage: 4,410
Insgesamt: 157,869
