Zum Hauptinhalt wechseln
The HP Pavilion 14m-cd0005dx is a touchscreen laptop designed by HP. It is 14.0-inches diagonal, with a 1366x768-pixel resolution display.
1 Fragen Alle anzeigen
Guidance on Screen replacement
How much more difficult does “touch screen” function make replacement? Are there many more caveats to screen replacement?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@eeandersen it is not much more difficult. You will just have a few more cables and connectors. Essentially the same work. You can download the maintenance and service guide for the HP Pavilion x360 14m-cd0005dx from here It'll guide you through the repair
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
@eeandersen, On your laptop the touch screen function is integrated into the LCD display, so there isn't any separate part to deal with; in fact, you can't replace them separately. As @oldturkey03 mentioned, there will be one more connector to route and plug in for the digitizer, but that's it for the difference between replacing your display and a simple LCD replacement.
von
Antwort hinzufügen
Eric Andersen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 105
