Zum Hauptinhalt wechseln
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Leaking on left side of radiator
Where is the leak coming from .I change out filler part and I still see fluid
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@ajmendez1975 could be a leaking hose or a leaking radiator. We really need to see where you are looking it and see if we can guide you further. The best test would be a pressure test. Not sure where you are located so it'll be kind of useless to tell you a store where you can get them from. Just do an online search for Radiator Pressure tester and see if that is something you want to invest in. If not, some radiator places will do this for you, but may charge you.
Bilder zu einer vorhandenen Frage hinzufügen
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Andrew Mendez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 81
