Zum Hauptinhalt wechseln
Nintendo’s first major revision of the 3DS released to Japan in October of 2014 and to North America in September of 2015. The 2015 3DS introduces improved 3D capabilities, a C-Stick, new internal amiibo support, and a new set of trigger buttons.
20 Fragen Alle anzeigen
3ds not reading sd cards
I was in the middle of homebrewing my 3ds when out of nowhere, my 3ds stopped reading my micro sd card. It worked before, so why not now? I tried moving the files to a different microsd card, reinserting the microsd card multiple times, but alas nothing worked. I’m starting to think there’s something wrong with the sad card reader in my 3ds.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yeah, card reader would be my guess too. Before you replace it though, there is one thing you can try. Take out the SD and put a drop or two of isopropyl alcohol (90%+) on the pins, then press the card in and out of the reader several times to try to clean the pins in there.
If that doesn't work: Nintendo 3DS 2015 SD Kartenleser Austausch
Don't worry, replacing the SD slot looks like one of the easiest repairs on this thing
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I think the pins just got dirty over time because when I put some isopropyl alcohol on it, it stared working again. Thanks!
von
Antwort hinzufügen
.skyden12 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 70
Insgesamt: 433
