Zum Hauptinhalt wechseln
Reparatur- und Demontage-Informationen für das Nokia G42 5G Android Smartphone, veröffentlicht im Juni 2023. Die Modelle haben die Modellnummern TA-1573, TA-1581 oder TA-1591.
System stuck at boot logo
Hello, my G42 is stuck at boot logo NOKIA.
I've gone in to recovery but there is no reset option to delete data and cache.
I even tried fastboot erase cache and data but that is locked.
Any ideas? I'm shocked that a ifixit compatible phone has no basic option for factory reset. Did Nokia/HMD mess up? :o
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
5 Kommentare
Can you add pictures so we see what you see in the menu?
Bilder zu einer vorhandenen Frage hinzufügen
von
There's nothing much to see. (edited post with image)
Options:
Reboot system
Enter Fastboot
Power Off
That's it.
von
@danthebrit What did you do before this happened to the phone?
von
Running a benchmark. I rebooted to run a another test and that's it.
That's besides the point. Really doesn't matter what was being done.
(No, nothing was opened and battery charged).
It stuck trying to load the core system, and as we can't see the current verbose log of the system loading like we would see on ubuntu/linux servers, I'm sure the OS needs rebuilding. Probably an issue loading the cache or data partition. Not uncommon and happens.
What i need to know is if there is a way to force a factory reset without being able to access android OS GUI.
von
@danthebrit If you don't care much about what is on the phone I think volume up and power button is the android hard reset button combination. If that is the way you entered the recovery mode however as it can differ based on device try the other volume button from the one in the recovery combination which in this example would be down.
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
All is fine. It just started working out of the blue.
Full reset done from OS and bootloader opened.
Case is closed!
Rant:
Still wish i knew if there was a way to force a rebuild of the OS. These phones seem to have removed any option to do a full factory reset from recovery. I guess it's for the case if the phone is stolen they can't use it?. It's silly as that can be remedied with a program file and QFIL for example. I'm sure their out there, build and ready for download.
Don't really get the hole reason behind removing the factory reset from recovery menu.
Knowing that with the IMEI details or even IMSI (and any other) and with proof of purchase or usage from carrier, you can provide that to the police and they will tag the phone as stolen/trace it.
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
I believe that's cpu problem, and can be fixed via reball.
Bewertung 1
I have this booting problem but I can't restart my phone because everytime I getting recovery mode my device power off and restart on booting please help me to I get my phone unlock
Bewertung 0
1 Kommentar:
Same thing with my phone loved on login screen when type password still will not unlock
von
Antwort hinzufügen
Dan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 24
Letzte 30 Tage: 78
Insgesamt: 1,139
