Zum Hauptinhalt wechseln
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Why is my washing machine not getting power
I have a Kenmore washer model number 110.21652020. we have change the power outlet to make sure it is working. The washer is acting as if it is not getting power
Thanks
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Hi @macyekuhn
Here's the tech sheet for the washer that may help.
Check if the diagnostic LED light on the control board is flashing or if it is on or is off - see the image on p.2 Diagnostic Led – Main Control (ACU) to find its location on the board.
If it is either ON or OFF (not flashing) then go to Test #1: Main Control (ACU) and follow the steps to check if the power cord and the control board are OK or not.
If the power cord is faulty search online for W11112935 to find suppliers that suit you best.
If the control board is faulty search online for W11413659 (or W11470214 - supersedes previous part number) to find suppliers that suit you best.
Be safety aware when testing the control board as there's exposed potentially lethal AC voltage on the board
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
MacyEKuhn wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 28
