Zum Hauptinhalt wechseln
Released in 2020 Model Number: RZ09-0330Q / RZ09-0330QEM3-R3U1
1 Fragen Alle anzeigen
Advice on how to replace thermal paste on CPU
Hi, my Razer Blade 15" Studio laptop has been running hotter and hotter as of late. I was able to open the back and extract quite a bit of dust from the bottom fans, which helped my issue somewhat, but not nearly as much as I would have hoped.
Since I've been using if for over 3 years now, I figure it would be wise to try applying new thermal paste to the CPU (I'm not sure if the discrete graphics card inside would also have thermal paste to replace, but if so then I'd guess it would be useful to replace that as well).
I have some experience following pre-existing iFixit guides, but certainly wouldn't know where to start on this task given that I can't find any information online about how the internals of this machine are laid out. If it would be useful, I can supply a picture of the inside after removing the back panel.
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar:
Please do supply a picture. I can help u from there
von
Einen Kommentar hinzufügen
1 Antwort
@mitchybemitchin great idea about posting an image of your board. To change your thermal paste, check this video Should be the same for your model. Bilder zu einer vorhandenen Frage hinzufügen
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
MitchyBeMitchin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 131
