Zum Hauptinhalt wechseln
iFixit verwendet Cookies, um die Funktionalität der Website zu verbessern, den Datenverkehr zu analysieren und Werbung zu personalisieren. Durch die Nutzung unserer Website stimmen Sie unserer Cookie-Nutzung und Datenschutzrichtlinie zu.
Inhaltsverzeichnis
2 Diagramme
Beliebte Fragen im Forum
Eine Frage stellen
Es gibt noch keine Fragen. Stelle du die erste!
Modelle
HR4013CQ
Background and Identification
The Makita Rotary Hammer model HR4013CQ is a corded rotary hammer drill with Anti-Vibration Technology (AVT). The Anti-Vibration Technology reduces the drill’s vibration to five meters per second squared. An integrated damper spring at the base of the drill’s impact bolt is designed to absorb impact vibrations from the drill bit. The HR4013CQ model is designed for a range of concrete applications, including drilling/coring through-holes for pipes, setting larger anchors, small chipping applications, and securing tilt-wall supports. It can be used by masons, concrete contractors, demolition contractors, sprinkler installers, general contractors, and demolition contractors.
The drill features an 11 Amp motor that delivers 8.4 foot-pounds (11.4 joules) of impact energy. This model features a lock-on or trigger-activated in the “chipping only” mode. The drill includes a push-button start/stop control and is sold with a hammer drill, side handle, depth rod, side grip, grease, and cloth. The drill’s constant speed control automatically applies additional power to the motor to maintain the same speed under heavier loads. A soft-start function suppresses the drill’s start-up reaction for better accuracy and more control.
An LED service light on the drill notifies the user approximately eight hours before the drill’s brushes need to be replaced. A separate LED power light indicates switch failure or cord damage. The Makita Rotary Hammer model HR4013CQ can be identified by the name “Makita” in cursive font on the drill’s handle and on the drill’s side.
Technical Specifications
Dimensions:
  • Product Depth (in.): 18.68
  • Product Height (in.): 10.375
  • Product Width (in.): 4.375
Details:
  • Amperage (amps): 11
  • Blow energy (ft.-lb.): 8.4
  • Chuck Size: 1-9/16 In.
  • Chuck Type: SDS-Max
  • Color Family: Teal
  • Cord Length (ft.): 15.6
  • Cordless/ Corded: Corded
  • Drill/ Driver Type: Rotary Drill
  • Included: No Additional Items Included
  • Maximum Speed (RPM): 500 RPM
  • Power Tool Features: Case Included, Variable Speed
  • Product Weight (lb.): 15.1
  • Tools Product Type: Power Tool
Additional Information
iRobot
1 Reputation
636 Anleitungen geschrieben
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 22
Insgesamt: 946
