Zum Hauptinhalt wechseln
Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement
Was du brauchst
  1. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Prepare your phone for disassembly: Schritt 1, Bild 1 von 1
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    Frag FixBot
    Kommentar hinzufügen
  2. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 2, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 2, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 2, Bild 3 von 3
    • Apply a suction cup to the back cover, as close to the center of the bottom edge as possible.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
    • If your back cover is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken back cover.
    Frag FixBot
  3. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: Schritt 3, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: Schritt 3, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the back cover adhesive: Schritt 3, Bild 3 von 3
    • During the next two steps, don't insert your opening pick deeper than 3 mm to prevent damaging the metal springs around the frame.
    • Optionally, you can measure and mark your opening pick at 3 mm to help you visualize the length.
    • Remove the suction handle from the back cover.
    • Slide the opening pick around the bottom left corner and up the left edge of the back cover to separate the adhesive.
    Frag FixBot
  4. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 4, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 4, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 4, Bild 3 von 3
    • Continue sliding the pick around the top left corner and across the top edge of the back cover.
    Frag FixBot
  5. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 5, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 5, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 5, Bild 3 von 3
    • The adhesive along the right edge of the back cover is thicker than the rest. You'll need to insert your opening pick at a minimum of 4 mm to separate the adhesive.
    • Slide your pick down the right edge and around the bottom right corner to separate the remaining adhesive.
    Frag FixBot
  6. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 6, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 6, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 6, Bild 3 von 3
    • Don't fully remove the back cover yet, as it's still connected to the phone by a cable.
    • At this point, the back cover should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the bottom edge of the back cover and swing it over the top edge of the phone.
    • Prop up the back cover with your suction handle or a clean, sturdy object—making sure that the cable isn't strained.
    Frag FixBot
  7. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket screw: Schritt 7, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket screw: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $31.41
    • While the Pixel 9 Pro Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 or T4 Torx bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the top bracket.
    Frag FixBot
  8. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket: Schritt 8, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top bracket: Schritt 8, Bild 2 von 2
    • Use tweezers, or your fingers, to pull the top bracket towards the top of the phone to release it from its clip.
    • Remove the top bracket.
    Frag FixBot
  9. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the back cover cable: Schritt 9, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the back cover cable: Schritt 9, Bild 2 von 2
    • Insert the tip of your spudger under the bottom edge of the back cover cable press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface‑mounted components.
    • Pry up and disconnect the back cover cable.
    Frag FixBot
  10. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover: Schritt 10, Bild 1 von 1
    • Lift the back cover off the frame and remove it.
    Frag FixBot
  11. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket screws: Schritt 11, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket screws: Schritt 11, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the base battery bracket.
    Frag FixBot
  12. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: Schritt 12, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: Schritt 12, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery bracket: Schritt 12, Bild 3 von 3
    • Use tweezers, or your fingers, to pull the base battery bracket toward the bottom of the phone to release it from its clip.
    • Remove the base battery bracket.
    Frag FixBot
  13. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the base battery: Schritt 13, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the base battery: Schritt 13, Bild 2 von 2
    • Insert the tip of your spudger under the bottom left corner of the base battery press connector, near the gold marker.
    • Pry up and disconnect the base battery.
    Frag FixBot
  14. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the USB-C port board cable: Schritt 14, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the USB-C port board cable: Schritt 14, Bild 2 von 2
    • Use a spudger to pry up and disconnect the USB-C port board cable press connector.
    Frag FixBot
  15. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket screws: Schritt 15, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket screws: Schritt 15, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the vibrator bracket.
    Frag FixBot
  16. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket: Schritt 16, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator bracket: Schritt 16, Bild 2 von 2
    • Use tweezers, or your fingers, to lift the vibrator bracket off the frame and remove it.
    Frag FixBot
  17. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the antenna cable: Schritt 17, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the antenna cable: Schritt 17, Bild 2 von 2
    • Slide one arm of a pair of angled tweezers under the metal neck of the black antenna cable's connector head on the USB‑C board.
    • Lift straight up to disconnect the cable.
    Frag FixBot
  18. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket screws: Schritt 18, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket screws: Schritt 18, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 2.6 mm‑long screws securing the inner front camera bracket.
    Frag FixBot
  19. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: Schritt 19, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: Schritt 19, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera bracket: Schritt 19, Bild 3 von 3
    • Use tweezers, or your fingers, to lift the inner front camera bracket up and toward the left edge of the phone to release its clips.
    • Remove the inner front camera bracket.
    Frag FixBot
  20. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner front camera: Schritt 20, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner front camera: Schritt 20, Bild 2 von 2
    • Use a spudger to pry up and disconnect the inner front camera press connector.
    Frag FixBot
  21. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: Schritt 21, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: Schritt 21, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner front camera: Schritt 21, Bild 3 von 3
    • Use the point of a spudger to pry up the inner front camera and separate the adhesive securing it to the frame.
    • Remove the inner front camera.
    Frag FixBot
  22. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: Schritt 22, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: Schritt 22, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the ultra wideband antenna: Schritt 22, Bild 3 von 3
    • Slide the flat end of a spudger under the ultra wideband antenna to separate the adhesive foam securing it to the frame.
    • Use tweezers, or your fingers, to lift the antenna off the frame to separate any remaining adhesive.
    Frag FixBot
  23. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket screws: Schritt 23, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket screws: Schritt 23, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 3.0 mm‑long screws securing the ultra wideband bracket.
    Frag FixBot
  24. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: Schritt 24, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: Schritt 24, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the ultra wideband bracket: Schritt 24, Bild 3 von 3
    • While holding the ultra wideband antenna out of the way, pull the bracket toward the bottom of the phone to release its clips.
    • Remove the ultra wideband bracket.
    Frag FixBot
  25. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screw: Schritt 25, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screw: Schritt 25, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the interconnect cable bracket.
    Frag FixBot
  26. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 26, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 26, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 26, Bild 3 von 3
    • Use tweezers, or your fingers, to pull the bracket toward the right edge of the phone to release its clip.
    • Remove the bottom interconnect cable bracket.
    Frag FixBot
  27. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket screw: Schritt 27, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket screw: Schritt 27, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the 3.0 mm‑long screw securing the inner display cable bracket.
    Frag FixBot
  28. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket: Schritt 28, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the inner display cable bracket: Schritt 28, Bild 2 von 2
    • Use tweezers, or your fingers, to pull the inner display cable bracket towards the left edge of the phone to release it from its clip.
    • Remove the inner display cable bracket.
    Frag FixBot
  29. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: Schritt 29, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: Schritt 29, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the inner display cable: Schritt 29, Bild 3 von 3
    • Insert the point of a spudger under the bottom left corner of the inner display press connector, next to the gold marker on the logic board.
    • Pry up and disconnect the inner display cable.
    Frag FixBot
  30. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 30, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 30, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 30, Bild 3 von 3
    • Repeat the previous step to disconnect the top and bottom interconnect cable press connectors, making sure to only pry next to the gold markers.
    Frag FixBot
  31. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the graphite sheet: Schritt 31, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the graphite sheet: Schritt 31, Bild 2 von 2
    • Peel the graphite sheet off the bottom speaker to separate the adhesive securing it.
    Frag FixBot
  32. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 32, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 32, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 32, Bild 3 von 3
    • Continue peeling the graphite sheet off the logic board to separate the remaining adhesive.
    Frag FixBot
  33. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the side buttons: Schritt 33, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the side buttons: Schritt 33, Bild 2 von 2
    • Use tweezers, or your fingers, to peel off the yellow tape on the side button cable ZIF connector.
    • Set the tape aside. You'll need it during reassembly.
    Frag FixBot
  34. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 34, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 34, Bild 2 von 2
    • Use the point of a spudger, or your fingernail, to lift the locking tab on the side button cable ZIF connector.
    Frag FixBot
  35. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 35, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 35, Bild 2 von 2
    • Use angled tweezers to pull the side button cable straight out of its slot.
    • Take care not to puncture the battery—it can leak dangerous chemicals and/or catch fire.
    Frag FixBot
  36. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the 5G mmWave antenna: Schritt 36, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the 5G mmWave antenna: Schritt 36, Bild 2 von 2
    • A thermal pad lightly adheres the 5G mmWave antenna to the frame.
    • Use the tip of a spudger to pry up the 5G mmWave antenna from the frame and separate it from the thermal pad.
    Frag FixBot
  37. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board screws: Schritt 37, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board screws: Schritt 37, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the three screws securing the logic board:
    • One 2.2 mm‑long screw
    • Two 2.6 mm‑long screws
    Frag FixBot
  38. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: Schritt 38, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: Schritt 38, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the logic board: Schritt 38, Bild 3 von 3
    • Insert the flat end of a spudger under the top left corner of the logic board, next to the inner front camera cutout.
    • You might feel some resistance since the logic board is bonded to the frame by thermal paste.
    • Pry up the logic board enough so you can grip the top edge with your fingers.
    Frag FixBot
  39. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 39, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 39, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 39, Bild 3 von 3
    • Lift the top of the logic board out of the frame and remove it.
    • Lay down the logic board upside down on a clean surface.
    Frag FixBot
  40. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: Schritt 40, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: Schritt 40, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Clean the thermal paste: Schritt 40, Bild 3 von 3
    • Use the flat end of a spudger to scrape away large pieces of old thermal paste from the frame.
    • Apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to any remaining thermal paste residue.
    • Wipe away the residue using a coffee filter or lint-free cloth.
    Frag FixBot
  41. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 41, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 41, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 41, Bild 3 von 3
    • Don't press down heavily on the logic board while cleaning it to prevent bending the metal springs or smudging the rear camera assembly.
    • Repeat the thermal paste cleaning procedure for the bottom of the logic board.
    Frag FixBot
  42. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: Schritt 42, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: Schritt 42, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the conductive fabric: Schritt 42, Bild 3 von 3
    • Use tweezers, or your fingers, to peel the section of conductive fabric connecting the loudspeaker to the frame.
    Frag FixBot
  43. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: Schritt 43, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: Schritt 43, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the cable adhesive: Schritt 43, Bild 3 von 3
    • Slide one arm of a pair of angled tweezers under the contact pad connected to the loudspeaker.
    • Lift the contact pad to separate the adhesive securing it to the frame.
    Frag FixBot
  44. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker screw: Schritt 44, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker screw: Schritt 44, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the 2.6 mm‑long screw securing the loudspeaker.
    Frag FixBot
  45. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker: Schritt 45, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the loudspeaker: Schritt 45, Bild 2 von 2
    • Use the tip of a spudger to pry up the left edge of the loudspeaker to separate the adhesive securing it to the frame.
    Frag FixBot
  46. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 46, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 46, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 46, Bild 3 von 3
    • Use your fingers to lift the top edge of the loudspeaker and pull it out of its recess in the frame.
    • Remove the loudspeaker.
    Frag FixBot
  47. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the USB-C port board adhesive: Schritt 47, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the USB-C port board adhesive: Schritt 47, Bild 2 von 2
    • Slide the tip of an opening pick under the USB-C port board cable to separate the adhesive securing it to the frame.
    Frag FixBot
  48. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board screws: Schritt 48, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board screws: Schritt 48, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the three 2.6 mm‑long screws securing the USB-C port board.
    Frag FixBot
  49. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board: Schritt 49, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the USB-C port board: Schritt 49, Bild 2 von 2
    • Use a spudger to pry up the top right corner of the USB-C port board to unclip it from the frame.
    Frag FixBot
  50. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 50, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 50, Bild 2 von 2
    • Pull the USB-C port board out of its recess in the frame and remove it.
    Frag FixBot
  51. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 51, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 51, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 51, Bild 3 von 3
    • Use your fingers to peel up the two edges of the pull tab on the base battery.
    Frag FixBot
  52. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 52, Bild 1 von 1
    • Unfold your phone and flip it so the inner screen is facing upward.
    • Use a hair dryer, or a heat gun, to heat the section of inner screen behind the base battery until the its barely too hot to touch.
    • Don't heat the screen longer than 30 seconds, as it's susceptible to heat damage.
    Frag FixBot
  53. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 53, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 53, Bild 2 von 2
    • Fold your phone and turn it so the base battery is facing up.
    • While holding the right pull tab, slide the left pull tab toward the top edge of the battery to separate the top section of adhesive.
    Frag FixBot
  54. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 54, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 54, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 54, Bild 3 von 3
    • The battery adhesive is strong. Be careful when pulling on the battery and reapply heat if necessary to avoid bending it.
    • Grip the ends of the plastic pull tabs with your fingers.
    • Pull straight up with constant, steady force to separate the adhesive under the battery. Work slowly and let time do the work for you until the adhesive separates.
    • Remove the base battery.
    • If you're having trouble separating the adhesive, apply more heat and try again.
    • If you're having a lot of trouble separating the adhesive, or if you feel like you might damage the battery, follow the next three steps for an alternate method.
    Frag FixBot
  55. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: Schritt 55, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: Schritt 55, Bild 2 von 2
    • The next two steps show how to apply isopropyl alcohol under the base battery.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol under the bottom edge of the base battery.
    Frag FixBot
  56. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 56, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 56, Bild 2 von 2
    • Lift the bottom edge of the phone to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
    Frag FixBot
  57. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 57, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 57, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the base battery: Schritt 57, Bild 3 von 3
    • Apply a suction cup to the center of the base battery.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to separate the base battery from the frame.
    Frag FixBot
  58. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Heat the vibrator: Schritt 58, Bild 1 von 1
    • Use a hair dryer, or a heat gun, to heat the vibrator until it's barely too hot to touch.
    Frag FixBot
  59. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: Schritt 59, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: Schritt 59, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the vibrator: Schritt 59, Bild 3 von 3
    • Insert one arm of a pair of angled tweezers in the notch at the bottom left corner of the vibrator.
    • Pry up with the tweezers to separate the adhesive securing it to the frame.
    • Remove the vibrator.
    Frag FixBot
  60. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 60, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 60, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Insert an opening pick: Schritt 60, Bild 3 von 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
    Frag FixBot
  61. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: Schritt 61, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: Schritt 61, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the adhesive: Schritt 61, Bild 3 von 3
    • During the next four steps, don't insert your opening pick deeper than 3 mm to prevent damaging internal components.
    • Optionally, you can measure and mark your opening pick 3 mm from the tip to help you visualize the length.
    • Slide the opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive.
    Frag FixBot
  62. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 62, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 62, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 62, Bild 3 von 3
    • Slide the pick around the top right corner and stop before the front camera.
    Frag FixBot
  63. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 63, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 63, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 63, Bild 3 von 3
    • Pull the opening pick out so only the tip is under the screen.
    • Slide the opening pick across the top edge of the screen until you're past the front camera.
    • Push your pick to its original depth before continuing.
    Frag FixBot
  64. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 64, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 64, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 64, Bild 3 von 3
    • Slide the opening pick around the top left corner and stop about two‑thirds down the left edge of the screen.
    • Don't slide the pick any farther, or you risk damaging the display cable.
    Frag FixBot
  65. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 65, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 65, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 65, Bild 3 von 3
    • Pull the opening pick out to a 2 mm depth and rotate the pick around the bottom left corner to separate the remaining adhesive.
    Frag FixBot
  66. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 66, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 66, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 66, Bild 3 von 3
    • Don't fully remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be free from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Lift the right edge of the screen and swing it over the left edge of the phone, like opening a book.
    • Prop up the screen with your suction handle or a clean, sturdy object.
    Frag FixBot
  67. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the display cable bracket screw: Schritt 67, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the display cable bracket screw: Schritt 67, Bild 2 von 2
    FixMat
    $31.41
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the display cable bracket.
    Frag FixBot
  68. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 68, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 68, Bild 2 von 2
    • Conductive tape secures the display cable bracket to the frame.
    • Use a spudger, or your fingers, to lift the display cable bracket enough to access the press connector underneath.
    Frag FixBot
  69. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the display cable: Schritt 69, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the display cable: Schritt 69, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the display cable press connector.
    Frag FixBot
  70. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the screen: Schritt 70, Bild 1 von 1
    • Lift the screen off the frame and remove it.
    Frag FixBot
  71. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the battery bracket screw: Schritt 71, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the battery bracket screw: Schritt 71, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the 2.0 mm‑long screw securing the battery bracket.
    Frag FixBot
  72. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the battery: Schritt 72, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the battery: Schritt 72, Bild 2 von 2
    • Conductive tape secures the battery connector bracket to the lower board.
    • Use tweezers, or your fingers, to move the battery bracket out of the way of the battery press connector.
    Frag FixBot
  73. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 73, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 73, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    Frag FixBot
  74. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the rubber block: Schritt 74, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the rubber block: Schritt 74, Bild 2 von 2
    • Use tweezers, or your fingers, to remove the rubber block covering a screw on the top board.
    Frag FixBot
  75. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket screws: Schritt 75, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket screws: Schritt 75, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the top interconnect cable bracket.
    Frag FixBot
  76. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket: Schritt 76, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top interconnect cable bracket: Schritt 76, Bild 2 von 2
    • Use tweezers, or your fingers, to remove the top interconnect cable bracket.
    Frag FixBot
  77. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the top interconnect cable: Schritt 77, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the top interconnect cable: Schritt 77, Bild 2 von 2
    • Insert the point of a spudger under the top right corner of the top interconnect cable press connector, near the golden marker.
    • Pry up and disconnect the top interconnect cable press connector.
    Frag FixBot
  78. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screws: Schritt 78, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket screws: Schritt 78, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
    Frag FixBot
  79. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 79, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 79, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the bottom interconnect cable bracket: Schritt 79, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the bottom interconnect cable bracket from the lower board.
    Frag FixBot
  80. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the bottom interconnect cable: Schritt 80, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Disconnect the bottom interconnect cable: Schritt 80, Bild 2 von 2
    • Insert a spudger under the right edge of the bottom interconnect cable press connector.
    • Pry up and disconnect the bottom interconnect cable.
    Frag FixBot
  81. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: Schritt 81, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: Schritt 81, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the SIM card tray: Schritt 81, Bild 3 von 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole and press firmly to eject it.
    • Remove the SIM card tray.
    Frag FixBot
  82. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: Schritt 82, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: Schritt 82, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Separate the battery cable adhesive: Schritt 82, Bild 3 von 3
    • Slide the flat end of a spudger under the flip battery cable to separate the adhesive.
    • Use tweezers, or your fingers, to lift the flip battery cable connector and fully separate it from the frame.
    Frag FixBot
  83. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 83, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 83, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 83, Bild 3 von 3
    • Use your fingers to peel both edges of the flip battery pull tabs off the battery.
    Frag FixBot
  84. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 84, Bild 1 von 1
    • Use a hair dryer, or a heat gun, to heat the section of inner screen behind the flip battery (the side with the SIM card cutout) until it's barely too hot to touch.
    Frag FixBot
  85. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 85, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 85, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 85, Bild 3 von 3
    • Fold your phone and turn it so the flip battery is facing up.
    • Pull up on alternating sides of the pull tab to slice through the adhesive on the upper half of the flip battery, stopping once you get to the top edge.
    • Try to not lose one of the sides of the pull tab under the battery. If you do, don't worry! Move to the next step for an alternate method to remove the battery.
    Frag FixBot
  86. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: Schritt 86, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply isopropyl alcohol: Schritt 86, Bild 2 von 2
    • The remaining adhesive is extremely strong. To avoid bending the battery, the next three steps show how to use isopropyl alcohol and a suction handle to remove it.
    • Apply a few drops of isopropyl alcohol (>90%) under the bottom edge of the flip battery.
    Frag FixBot
  87. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 87, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 87, Bild 2 von 2
    Frag FixBot
  88. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 88, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 88, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the flip battery: Schritt 88, Bild 3 von 3
    • Apply a suction handle to the center of the flip battery.
    • While securing the phone with one hand, pull up on the suction cup with strong, steady force to separate the flip battery from the frame.
    • If the flip battery doesn't budge after applying constant pressure, apply more isopropyl alcohol and try again.
    • Remove the flip battery.
    Frag FixBot
  89. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board screw: Schritt 89, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board screw: Schritt 89, Bild 2 von 2
    • Use a Torx Plus 3IP driver to remove the 2.2 mm‑long screw securing the top board.
    Frag FixBot
  90. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: Schritt 90, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: Schritt 90, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the top board: Schritt 90, Bild 3 von 3
    • Insert the flat end of a spudger under the bottom edge of the top board.
    • Twist the spudger to lift the top board enough to unclip it from the frame.
    • Remove the top board.
    Frag FixBot
  91. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, End of disassembly: Schritt 91, Bild 1 von 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
    Frag FixBot
  92. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: Schritt 92, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: Schritt 92, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top board: Schritt 92, Bild 3 von 3
    • Press the top edge of the top board against the frame at a downward angle to engage its metal spring.
    • Press the board flat to the frame, making sure the screw holes are aligned.
    Frag FixBot
  93. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 93, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 93, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the top board.
    Frag FixBot
  94. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 94, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 94, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 94, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the old flip battery adhesive from the frame.
    Frag FixBot
  95. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 95, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 95, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 95, Bild 3 von 3
    • Apply isopropyl alcohol (>90%) and use a coffee filter or microfiber cloth to clean any adhesive residue.
    Frag FixBot
  96. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 96, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 96, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 96, Bild 3 von 3
    • The adhesives for the flip battery cable and connector are separate from the main adhesive strip.
    • Place the flip battery cable and connector adhesives over the frame, using the white outlines to confirm their orientation.
    • The clear liners should face the frame.
    • Peel the adhesive strips off their liners and place them over their respective spots on the frame.
    Frag FixBot
  97. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 97, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 97, Bild 2 von 2
    • Use the flat end of a spudger, or your fingers, to press down on the adhesive strips to adhere them to the frame.
    Frag FixBot
  98. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 98, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 98, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 98, Bild 3 von 3
    • Peel the main flip battery adhesive strip from its clear liner.
    • Align the top edge of the adhesive strip with the top edge of the battery recess.
    • The pull tab should be in the bottom left corner of the frame.
    • Lay the adhesive strip on the frame.
    Frag FixBot
  99. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 99, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 99, Bild 2 von 2
    • Use the flat end of a spudger, or your fingers, to press down the individual adhesive strips to adhere them to the frame.
    Frag FixBot
  100. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 100, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 100, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 100, Bild 3 von 3
    • Use the pull tab to peel the colored liner off to expose the adhesive.
    Frag FixBot
  101. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 101, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 101, Bild 2 von 2
    • Peel off the colored liners on the flip battery cable and connector adhesive.
    Frag FixBot
  102. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the flip battery: Schritt 102, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the flip battery: Schritt 102, Bild 2 von 2
    • Align the top edge of the flip battery with the top edge of the battery well.
    • Lay the battery over the frame.
    Frag FixBot
  103. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 103, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 103, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 103, Bild 3 von 3
    • Press down along the perimeter of the flip battery to adhere it to the frame.
    • Press down the flip battery cable and its connector to adhere it.
    • Let the phone sit for an hour for the adhesive to cure.
    Frag FixBot
  104. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: Schritt 104, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: Schritt 104, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinsert the SIM card tray: Schritt 104, Bild 3 von 3
    • While holding the lower board in place, reinsert the SIM card tray.
    Frag FixBot
  105. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the bottom interconnect cable: Schritt 105, Bild 1 von 1
    • Reconnect the bottom interconnect cable press connector.
    Frag FixBot
  106. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: Schritt 106, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: Schritt 106, Bild 2 von 2
    • Place the bottom interconnect cable bracket on the lower board and align its screw holes.
    Frag FixBot
  107. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 107, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 107, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the bottom interconnect cable bracket.
    Frag FixBot
  108. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the top interconnect cable: Schritt 108, Bild 1 von 1
    • Reconnect the top interconnect cable press connector.
    Frag FixBot
  109. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top interconnect cable bracket: Schritt 109, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top interconnect cable bracket: Schritt 109, Bild 2 von 2
    • Place the top interconnect cable bracket on the top board and align its screw holes.
    Frag FixBot
  110. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 110, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 110, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 2.2 mm‑long screws securing the top interconnect cable bracket.
    Frag FixBot
  111. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the rubber block: Schritt 111, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the rubber block: Schritt 111, Bild 2 von 2
    • Place the rubber block over its spot on the top board and press it down.
    Frag FixBot
  112. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the flip battery: Schritt 112, Bild 1 von 1
    • Reconnect the flip battery press connector.
    Frag FixBot
  113. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the flip battery bracket: Schritt 113, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the flip battery bracket: Schritt 113, Bild 2 von 2
    • Lay the flip battery bracket over the press connector and align the screw holes.
    Frag FixBot
  114. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 114, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 114, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 2.0 mm‑long screw securing the battery bracket.
    Frag FixBot
  115. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 115, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 115, Bild 2 von 2
    • If your outer screen adhesive at the bottom left corner isn't sticky anymore, follow the next four steps to replace it. Otherwise, skip the next four steps.
    • Use a spudger, or your fingers, to remove the old bottom left outer screen adhesive.
    • Use isopropyl alcohol (>90%) and a coffee filter or a microfiber cloth to remove any adhesive residue.
    Frag FixBot
  116. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: Schritt 116, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: Schritt 116, Bild 2 von 2
    • Before removing any liners, check if the bottom left outer screen adhesive matches the frame.
    • The clear liner should face the frame.
    Frag FixBot
  117. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 117, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 117, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 117, Bild 3 von 3
    • Peel the bottom left outer screen adhesive off its clear liner to expose the adhesive.
    • Put the adhesive into place on the frame.
    Frag FixBot
  118. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 118, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 118, Bild 2 von 2
    • Use the flat end of a spudger to press along the adhesive strip to adhere it to the frame.
    Frag FixBot
  119. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 119, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 119, Bild 2 von 2
    • Before removing any liners, check if the perimeter outer screen adhesive matches the frame.
    Frag FixBot
  120. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 120, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 120, Bild 2 von 2
    • Be careful during this step, as it's easy to stick the adhesive in the wrong spot. Take your time and work slowly.
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded.
    Frag FixBot
  121. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 121, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 121, Bild 2 von 2
    • Align the top half of the adhesive over the frame, using the corners as reference points.
    • Place the adhesive on the frame.
    Frag FixBot
  122. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 122, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 122, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 122, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the top edge of the adhesive and adhere it to the frame.
    Frag FixBot
  123. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 123, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 123, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 123, Bild 3 von 3
    • While peeling away the rest of the clear liner, slowly lay the rest of the adhesive over the perimeter of the phone.
    Frag FixBot
  124. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 124, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 124, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 124, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the rest of the adhesive and adhere it to the frame.
    Frag FixBot
  125. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 125, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 125, Bild 2 von 2
    • Use the tip of a spudger to pry up the segmented tab on the bottom left corner of the large blue liner.
    Frag FixBot
  126. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 126, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 126, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 126, Bild 3 von 3
    • Lift the tab and peel off the large blue liner to expose the secondary liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it to the frame.
    Frag FixBot
  127. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the outer screen: Schritt 127, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the outer screen: Schritt 127, Bild 2 von 2
    • Support the screen with your hand or prop it up on something sturdy.
    • Reconnect the outer screen cable press connector.
    Frag FixBot
  128. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the outer screen cable bracket: Schritt 128, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the outer screen cable bracket: Schritt 128, Bild 2 von 2
    • Reinsert the outer screen cable bracket clip under the frame and align its screw hole.
    Frag FixBot
  129. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 129, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 129, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 2.2 mm‑long screw securing the display cable bracket.
    Frag FixBot
  130. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: Schritt 130, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: Schritt 130, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Expose the adhesive: Schritt 130, Bild 3 von 3
    • Remove the blue liner from the bottom left outer screen adhesive strip.
    • While holding the screen above the frame, separate one of the secondary liner's pull tabs at the bottom left corner.
    Frag FixBot
  131. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 131, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 131, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 131, Bild 3 von 3
    • Still holding the screen, peel off the secondary liner to expose the adhesive.
    Frag FixBot
  132. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the outer screen: Schritt 132, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the outer screen: Schritt 132, Bild 2 von 2
    • Align the outer screen over the frame and press it into place.
    Frag FixBot
  133. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 133, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 133, Bild 2 von 2
    • Press along the perimeter of the outer screen to adhere it to the frame.
    • Optionally, you can use a hair dryer or heat gun to lightly heat the edges of the back cover and create a stronger bond.
    • Let the phone sit a few hours for the adhesive to cure.
    Frag FixBot
  134. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator: Schritt 134, Bild 1 von 1
    Tesa 61395 Tape
    $8.95
    • Flip your phone over.
    • If your replacement inner screen assembly comes with adhesive pre‑installed over the vibrator cutout, remove its liner. Otherwise, use a thin double‑sided tape to replace the adhesive.
    • Align the vibrator over its cutout on the frame and press down to adhere it.
    Frag FixBot
  135. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 135, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 135, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 135, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the old base battery adhesive from the frame.
    Frag FixBot
  136. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: Schritt 136, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your new adhesive: Schritt 136, Bild 2 von 2
    • Before removing any liners, check that your base battery adhesive matches the size and shape of the cutout in the frame.
    Frag FixBot
  137. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 137, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 137, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 137, Bild 3 von 3
    • Peel off the adhesive strip from its clear liner.
    • Align the adhesive strip with the top edge of the base battery recess and press it onto the frame.
    Frag FixBot
  138. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 138, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 138, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 138, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the five adhesive strips and adhere them to the frame.
    Frag FixBot
  139. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 139, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 139, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 139, Bild 3 von 3
    • Peel off the colored liner to expose the adhesive strips.
    Frag FixBot
  140. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: Schritt 140, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: Schritt 140, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Install the new base battery: Schritt 140, Bild 3 von 3
    • Align the new base battery with the top edge of the battery recess and press it to the frame.
    Frag FixBot
  141. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 141, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 141, Bild 2 von 2
    • Use your fingers to press along the battery to adhere it to the frame.
    Frag FixBot
  142. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the USB-C port board: Schritt 142, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the USB-C port board: Schritt 142, Bild 2 von 2
    • Reinsert the USB-C port board into its recess in the frame.
    Frag FixBot
  143. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 143, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 143, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 143, Bild 3 von 3
    • Press the USB-C port board flat to the frame to re-engage the metal springs, making sure the alignment pegs fit into their holes in the board.
    Frag FixBot
  144. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 144, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 144, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 144, Bild 3 von 3
    • While holding the board in place, use a Torx Plus 3IP driver to install the three 2.6 mm‑long screws securing the USB-C port board.
    Frag FixBot
  145. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 145, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 145, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 145, Bild 3 von 3
    • If the adhesive on your USB-C port cable isn't sticky or intact, follow the next two steps to install new adhesive. Otherwise, skip those steps.
    • Use tweezers, or your fingers, to remove the old adhesive under the USB-C port cable.
    • Peel the new USB-C port cable adhesive strip from its clear liner.
    • Align the adhesive strip over its spot in the frame and lay it down with the colored pull tab facing the right edge of the phone.
    Frag FixBot
    Kommentar hinzufügen
  146. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 146, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 146, Bild 2 von 2
    • Use the flat end of a spudger, or your fingers, to press down the adhesive and adhere it to the frame.
    • Peel off the colored liner to expose the adhesive.
    Frag FixBot
  147. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 147, Bild 1 von 1
    • Press the USB-C port board cable to the frame to re-adhere it.
    Frag FixBot
  148. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 148, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 148, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 148, Bild 3 von 3
    • The next six steps show how to replace the conductive fabric on the bottom of your loudspeaker and the adhesive on the loudspeaker's cable. Skip these steps if your fabric and adhesive are intact.
    • Use tweezers, or your fingers, to remove the bottom and top conductive fabrics or the loudspeaker cable adhesive if they're not intact.
    Frag FixBot
  149. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the bottom conductive fabric: Schritt 149, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the bottom conductive fabric: Schritt 149, Bild 2 von 2
    • Align the bottom loudspeaker conductive fabric on the underside of the loudspeaker.
    • Refer to the second photo for the correct orientation.
    Frag FixBot
  150. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 150, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 150, Bild 2 von 2
    • Remove the conductive fabric from its clear and colored liners and lay it over its spot on the loudspeaker.
    Frag FixBot
  151. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 151, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 151, Bild 2 von 2
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the loudspeaker.
    Frag FixBot
  152. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 152, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 152, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the adhesive: Schritt 152, Bild 3 von 3
    • Peel the clear liner off the loudspeaker cable adhesive.
    • Align the adhesive over the loudspeaker cable and lay it down, making sure not to cover the hole in the cable.
    Frag FixBot
  153. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 153, Bild 1 von 1
    • Use your fingers to lightly pinch the cable and adhere the adhesive strip.
    • Remove the blue liner from the adhesive strip.
    Frag FixBot
  154. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the loudspeaker: Schritt 154, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the loudspeaker: Schritt 154, Bild 2 von 2
    • Align the hole in the loudspeaker cable over its peg on the frame.
    • Press down the cable with the tip of a spudger, or your finger, to adhere it to the frame.
    Frag FixBot
  155. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 155, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 155, Bild 2 von 2
    • While pressing the cable down, reinsert the loudspeaker at an angle into its recess and press it flat to the frame.
    Frag FixBot
  156. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 156, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 156, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 156, Bild 3 von 3
    • While holding the loudspeaker in place, use a Torx Plus 3IP driver to install the 2.6 mm‑long screw securing the loudspeaker.
    Frag FixBot
  157. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the top conductive fabric: Schritt 157, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the top conductive fabric: Schritt 157, Bild 2 von 2
    • The next four steps show how to replace the conductive fabric on the top of the loudspeaker. Skip these steps if your fabric is still intact.
    • Peel off the clear liner on the top loudspeaker conductive fabric.
    • Peel off the small colored liner covering the rounded corner of the fabric.
    Frag FixBot
  158. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 158, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 158, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 158, Bild 3 von 3
    • Align the rounded corner of the conductive fabric with the same‑shaped marking on the frame.
    • Lay the fabric down onto the frame and the loudspeaker.
    Frag FixBot
  159. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 159, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 159, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 159, Bild 3 von 3
    • Use the flat end of a spudger, or your fingers, to press down the conductive fabric and adhere it to the frame and loudspeaker.
    Frag FixBot
  160. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 160, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 160, Bild 2 von 2
    • Peel off the large colored liner from the conductive fabric.
    Frag FixBot
  161. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: Schritt 161, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: Schritt 161, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply new thermal paste: Schritt 161, Bild 3 von 3
    • Apply small beads of thermal paste (five total) to the motherboard in the same locations as the old thermal paste.
    Frag FixBot
  162. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the logic board: Schritt 162, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the logic board: Schritt 162, Bild 2 von 2
    • Place the logic board back into its cutout in the frame, making sure no cables get trapped underneath it.
    Frag FixBot
  163. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 163, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 163, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the three screws securing the logic board:
    Frag FixBot
  164. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the side button cable: Schritt 164, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the side button cable: Schritt 164, Bild 2 von 2
    • Use angled tweezers to push the side button cable back into its slot.
    Frag FixBot
  165. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 165, Bild 1 von 1
    • Flip the locking tab down and lightly press on it until it clicks into place.
    Frag FixBot
  166. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 166, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 166, Bild 2 von 2
    • Place the yellow tape over the ZIF connector and its cable.
    Frag FixBot
  167. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: Schritt 167, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: Schritt 167, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new graphite sheet: Schritt 167, Bild 3 von 3
    • Peel the clear liner off your replacement graphite sheet to expose the adhesive on the upper half.
    • Align the upper half of the graphite sheet over the logic board and lay it down.
    Frag FixBot
  168. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 168, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 168, Bild 2 von 2
    • Use your finger to press down the upper half of the graphite sheet and secure it to the logic board.
    Frag FixBot
  169. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 169, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 169, Bild 2 von 2
    • Remove the blue liner from the bottom of the graphite sheet to expose the adhesive underneath.
    Frag FixBot
  170. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 170, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 170, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 170, Bild 3 von 3
    • Drag your finger from the middle section of the graphite sheet to the adhesive spot on the loudspeaker to flatten the graphite sheet and adhere it.
    Frag FixBot
  171. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 171, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 171, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 171, Bild 3 von 3
    • Grip the pull tab at the top of the graphite sheet and peel off the remaining liner.
    Frag FixBot
  172. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: Schritt 172, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: Schritt 172, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the right side cables: Schritt 172, Bild 3 von 3
    • Reconnect the inner display cable and the top and bottom interconnect cable press connectors.
    Frag FixBot
  173. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner display cable bracket: Schritt 173, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner display cable bracket: Schritt 173, Bild 2 von 2
    • Reinsert the inner display cable bracket clip under its slot in the logic board and align the screw holes.
    Frag FixBot
  174. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 174, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 174, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the inner display cable bracket.
    Frag FixBot
  175. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: Schritt 175, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the bottom interconnect cable bracket: Schritt 175, Bild 2 von 2
    • Reinsert the bottom interconnect bracket clip under its slot in the frame and align the screw hole.
    Frag FixBot
  176. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 176, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 176, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the interconnect cable bracket.
    Frag FixBot
  177. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the ultra wideband bracket: Schritt 177, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the ultra wideband bracket: Schritt 177, Bild 2 von 2
    • While holding the ultra wideband antenna out of the way, reinsert the ultra wideband bracket clip under its slot in the frame and align the screw holes.
    Frag FixBot
  178. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 178, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 178, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the ultra wideband bracket.
    Frag FixBot
  179. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: Schritt 179, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: Schritt 179, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Replace the ultra wideband bracket adhesive: Schritt 179, Bild 3 von 3
    • If the adhesive on your ultra wideband bracket is still sticky, skip this step.
    • Remove the old adhesive and foam on the ultra wideband bracket and under the antenna.
    • Replace the corresponding adhesive and foam to the bracket and the frame.
    • Press the ultra wideband antenna to the frame and re‑adhere it.
    Frag FixBot
  180. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 180, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 180, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 180, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the old adhesive foam from the inner front camera cutout.
    • Use isopropyl alcohol (>90% or greater) and a coffee filter or lint‑free cloth to remove any adhesive residue.
    Frag FixBot
  181. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 181, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 181, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 181, Bild 3 von 3
    • Peel the replacement inner front camera adhesive foam off its clear liner to expose the adhesive underneath.
    • Align the adhesive foam over the cutout in the frame so that the pull tab is facing the bottom of the phone.
    • Place the adhesive in the cutout.
    Frag FixBot
  182. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 182, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 182, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 182, Bild 3 von 3
    • Use the tip of a spudger to press along the edges of the adhesive foam to secure it to the frame.
    Frag FixBot
  183. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 183, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 183, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 183, Bild 3 von 3
    • Use tweezers, or your fingers, to peel off the colored liner and expose the adhesive underneath.
    Frag FixBot
  184. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera: Schritt 184, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera: Schritt 184, Bild 2 von 2
    • While holding the inner front camera above its cutout, reconnect its press connector.
    • Lay the inner front camera in its cutout and press down to secure it to the adhesive.
    Frag FixBot
  185. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: Schritt 185, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: Schritt 185, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the inner front camera bracket: Schritt 185, Bild 3 von 3
    • Reinsert the inner front camera bracket clip under its slot in the logic board and align the screw holes.
    Frag FixBot
  186. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 186, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 186, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 2.6 mm‑long screws securing the inner front camera bracket.
    Frag FixBot
  187. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the antenna cable: Schritt 187, Bild 1 von 1
    • Use tweezers to hold the antenna cable's connector in place over its socket and gently press down with your finger or a spudger until the connector snaps into place.
    Frag FixBot
  188. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator bracket: Schritt 188, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the vibrator bracket: Schritt 188, Bild 2 von 2
    • Place the vibrator bracket on the logic board and align its screw holes.
    Frag FixBot
  189. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 189, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 189, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the vibrator bracket.
    Frag FixBot
  190. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the USB-C port board cable: Schritt 190, Bild 1 von 1
    • Reconnect the USB-C port board cable press connector.
    Frag FixBot
  191. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the base battery: Schritt 191, Bild 1 von 1
    • Reconnect the base battery press connector.
    Frag FixBot
  192. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the base battery bracket: Schritt 192, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the base battery bracket: Schritt 192, Bild 2 von 2
    • Reinsert the base battery bracket clip under its slot in the logic board and align its screw holes.
    Frag FixBot
  193. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 193, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 193, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the two 3.0 mm‑long screws securing the base battery bracket.
    Frag FixBot
  194. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 194, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the old adhesive: Schritt 194, Bild 2 von 2
    • Use a spudger, or your fingers, to remove the old back cover adhesive.
    Frag FixBot
  195. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: Schritt 195, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: Schritt 195, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the back cover liners: Schritt 195, Bild 3 von 3
    • If you're replacing your back cover with a new one, follow the next two steps. Otherwise, skip them.
    • Use tweezers, or your fingers, to remove the three rear camera liners from the inside of your new back cover.
    Frag FixBot
  196. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 196, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 196, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 196, Bild 3 von 3
    • Peel off the remaining clear liners on the outside of the back cover.
    Frag FixBot
  197. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your adhesive: Schritt 197, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Compare your adhesive: Schritt 197, Bild 2 von 2
    • Before removing any liners, check if the adhesive matches the frame.
    Frag FixBot
  198. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 198, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 198, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Apply the new adhesive: Schritt 198, Bild 3 von 3
    • Peel away the top half of the new adhesive strip from its clear liner and keep it folded before continuing.
    Frag FixBot
  199. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 199, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 199, Bild 2 von 2
    Frag FixBot
  200. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 200, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 200, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 200, Bild 3 von 3
    Frag FixBot
  201. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 201, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 201, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 201, Bild 3 von 3
    Frag FixBot
  202. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 202, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 202, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 202, Bild 3 von 3
    • Use a spudger to pry up the segmented tab on the bottom right corner of the large blue liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
    Frag FixBot
  203. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reconnect the back cover cable: Schritt 203, Bild 1 von 1
    • While holding the back cover or propping it up, reconnect the back cover cable.
    • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    Frag FixBot
  204. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top bracket: Schritt 204, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Reinstall the top bracket: Schritt 204, Bild 2 von 2
    • Reinsert the top bracket clip under its slot in the logic board and align its screw hole.
    Frag FixBot
  205. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 205, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 205, Bild 2 von 2
    • Use a Torx Plus 3IP driver to install the 3.0 mm‑long screw securing the top bracket.
    Frag FixBot
  206. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the secondary liner: Schritt 206, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Remove the secondary liner: Schritt 206, Bild 2 von 2
    • Use the tip of a spudger to pry up the segmented tab on the top right corner of the secondary liner.
    Frag FixBot
  207. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 207, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 207, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 207, Bild 3 von 3
    • Peel off the secondary liner to expose the adhesive.
    Frag FixBot
  208. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the back cover: Schritt 208, Bild 1 von 2 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement, Secure the back cover: Schritt 208, Bild 2 von 2
    • Align the top edge of the back cover with the frame and press down to adhere it.
    Frag FixBot
  209. Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 209, Bild 1 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 209, Bild 2 von 3 Google Pixel 9 Pro Fold Inner Screen Asssembly Replacement: Schritt 209, Bild 3 von 3
    • Press along the perimeter of the back cover to adhere it to the frame.
    Frag FixBot
Abschluss
Congratulations on completing your repair!
For optimal performance, calibrate your newly installed batteries after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 9 Pro Fold Answers Community for help.
Eine weitere Person hat diese Anleitung absolviert.
Alex Diaz-Kokaisl
239.265 Reputation
1.171 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.947 Anleitungen geschrieben
5 Kommentare zur Anleitung
The title is incorrect. The manual doesn't show disassembly nor assembly of inner folding screen.
Marc - Antwort Teilen
I agree. This doesn't show anything to do with inner screen replacement
Gina Kenney - Antwort Teilen
the inner screen assembly is like part 0 that everything is build around ?
Wouter Hendrickx - Antwort Teilen
The instructions do not mention removing and/or replacing the inner screen. Only time it's mentioned is to heat it twice.
This needs correction
Austyn - Antwort Teilen
This device actually has a service kit provided for the inner screen replacements. When replacing the inner screen on this device it comes with the frame and various connectors.
Cici - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 70
Letzte 30 Tage: 304
Insgesamt: 7,672
