Zum Hauptinhalt wechseln
OnePlus 3 Hauptplatine austauschen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 4
OnePlus 3 Motherboard Replacement: Schritt 0, Bild 1 von 3 OnePlus 3 Motherboard Replacement: Schritt 0, Bild 2 von 3 OnePlus 3 Motherboard Replacement: Schritt 0, Bild 3 von 3
  • Make sure you have ejected the SIM tray before performing this step.
  • The motherboard is still held in place near the top by clips.
  • Slide the flat end of a spudger underneath the top left corner of the motherboard.
  • Twist the spudger and pry up to release the motherboard from its recess.
Schiebe das flache Ende des Spudgers unter die obere linke Ecke der Hauptplatine.
Verdrehe den Spudger und heble ihn hoch, so dass die Hauptplatine aus ihrer Vertiefung herauskommt.
+[* icon_note] Make sure you have ejected the SIM tray before performing this step.
+[* red] The motherboard is still held in place near the top by clips.
[* black] Slide the flat end of a spudger underneath the top left corner of the motherboard.
[* black] Twist the spudger and pry up to release the motherboard from its recess.
