Zum Hauptinhalt wechseln
HMD Pulse+ Back Cover Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 3
HMD Pulse+ Back Cover Replacement, Transfer the rear camera lens covers: Schritt 0, Bild 1 von 3 HMD Pulse+ Back Cover Replacement, Transfer the rear camera lens covers: Schritt 0, Bild 2 von 3 HMD Pulse+ Back Cover Replacement, Transfer the rear camera lens covers: Schritt 0, Bild 3 von 3
  • This step shows how to remove and transfer the two rear camera lens covers.
  • Apply a heated iOpener to the rear camera lens covers for one minute to soften their adhesive.
  • Alternatively, you can use a hair dryer to heat the lens covers. Be careful not to overheat them, as they may warp.
  • Wrap a soft cloth around the flat end of a spudger (to prevent scratching the cover) and push firmly on the back of the lens cover to separate its adhesive.
  • Remove the lens cover.
  • Use tweezers to remove any adhesive from the lens cover.
  • Repeat the process to remove the other lens cover.
  • During reassembly, transfer the original lens covers to your new back cover. To do this, remove the lens cover adhesive liners and press the covers into place to secure them. Use a clean cloth to wipe the lens covers before continuing with reassembly.
Hier Übersetzung einfügen
