Zum Hauptinhalt wechseln
Keurig K-Duo Water Pump Replacement
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Keurig K-Duo Water Pump Replacement: Schritt 0, Bild 1 von 2 Keurig K-Duo Water Pump Replacement: Schritt 0, Bild 2 von 2
  • There are two terminal blocks to remove from the motherboard.
  • Gently disconnect the 2-pin terminal block that has the label "Water Pump" on the motherboard.
  • Gently disconnect the 4-pin terminal block that has the label "IR Sensor."
Hier Übersetzung einfügen
