Zum Hauptinhalt wechseln
Anleitungen
Dokumente
Ersatzteile
Werkzeuge
Modelle
0132301056, 3057, 4185, BAR12, BAR12FU, BAR140, BAR18, BAR32, BAR390, BAR41, BAR42, BAR42E, BAR51, BAR52, BAR6U, BAR8IU, BAR9I, BARM100U, BARM29U, BCM8450UC
272 weitere anzeigen BCM8450UC/03, BCM8450UC/04, BCM8450UC/05, BCM8450UC/09, BCO110, BCO120T, BCO130T, BCO264B, BCO320T, BCO330T, BCO430, BCO430BM, BCO432, BCO70, CAM51015B, CAM51025MB, CAM51035M, CC100IU, CM041, CM044, COM530M, COM532M, D14, D31, D4B, D612, D650, D660, D665, D895, D895C, D895UX, D986, DC312T, DC412T, DC412TTC, DC414T, DC514T, DCF210TTC, DCF212T, DCF2210TTC, DCF2212T, DCF6212TTC, DCF6214T, DCM020ST, DCM024BK, DCM025GR, DCM028, DCM029, DCM02BK, DCM02BL, DCM02GR, DCM02OR, DCM02RE, DCM02ST, DCM040, DCM041, DCM043, DCM044, DCM045, DCM047, DCM048, DCM049, DCM04RE, DCM1385OR, DCR902T, DE40P, DE50P, DE650P, DEN500P, DES020, DES020S, DES021, DES023, DES024, DES025, DES027, DES028, DES029, DFH233, DH100P, DH40P, DO1279, DO1280S, DO1289, EAM3200, EAM3300, EAM3400, EAM3400N, EAM3500, EAM3500N, EAM4000, EAM4000B, EAM4400, EAM4500, EC140B, EC140BEXC, EC155, EC220CD, EC260BK, EC270, EC330, EC460, EC5, EC5W, EC6, EC610, EC680BK, EC680BM, EC680BMC, EC680M, EC680M Dedica, EC680R, EC680R Dedica Red, EC685BK, EC685BK Dedica Deluxe, EC685M, EC685M Dedica Deluxe, EC685R, EC685R Dedica Deluxe, EC685W, EC685W Dedica Deluxe, EC700, EC701, EC702, EC710, EC730, EC860, EC885M, EC9155MB, EC9335BK, EC9335M, EC9335R, EC9335REX4, EC9355M, EC9665M, ECAM22110B, ECAM22110SB, ECAM23120SB, ECAM23120SBS11, ECAM23210B, ECAM23210SB, ECAM23260, ECAM23260SB, ECAM23270S, ECAM23450SL, ECAM23460, ECAM25462S, ECAM26455M, ECAM28465B, ECAM28465M, ECAM28465MD, ECAM29034SB, ECAM29043SB, ECAM29063SB, ECAM29084SB, ECAM35020B, ECAM35020W, ECAM35025SB, ECAM35075SI, ECAM37095TI, ECAM44660B, ECAM45055S, ECAM45760B, ECAM46860S, ECO310BK, ECO310R, ECO310W, ECP3120, ECP3220, ECP3220R, ECP3220W, ECP3420, ECP3620, ECP3630, EDG455, EDG656TEX1, EMF2BK, EMFIBK, EMK6, EMK6A, EMK6YL, EN267BAE, EN520B, EN520BEX1, EN520R, EN560S, EN680M, EN750MB, EO12001B, EO1200B, EO1238, EO1251, EO1258, EO1260, EO1270, EOP2046, ESAM04110B, ESAM04110S, ESAM2000, ESAM3300, ESAM3300EXD, ESAM3300EXHD, ESAM3300S, ESAM3500, ESAM3500N, ESAM4400, ESAM4500, ESAM5400, ESAM5500, ESAM5500B, ESAM5500M, ESAM5600, ESAM5600SL, ESAM6600, ESAM6620, ESAM6700, ESAM6900, ESAM6900M, FH1130/1BK, FH1163/1BK, FH1363/1BK, ICM17270, KF180BLACK, KF180TITAN, KF180WHITE, KF510, KF5350BK, KF5350WH, KF550, KF5650BK, KF580, KF600, KF600BLACK, KF600WHITE, KF6031BK, KF6050WH, KF7000BK, KF7070SI, KF7150BK, KF7155, KF7170BK, KF7170SI, KF7175, KF7370SI, KF9050BK, KF9070SI, KF9150BK, KF9150WH, KF9170SI, KG521M, KMM30BLACK, KMM30WHITE, KSM2, KSM4, M810, M850, M870220W, M870280W, M880220W, M880280W, MR310, MR330, MR400, MR430, PACT100P, PACT110P, PACT140HPEC, PENTA, TA1200, TA1400, VVX1470GA
Allgemein
Kaffeemaschinen sind Geräte zum bequemen Zubereiten von Kaffee zu Hause oder im gewerblichen Bereich. Es gibt sie in verschiedenen Ausführungen, die jeweils unterschiedliche Methoden nutzen, um Aromen aus Kaffeesatz zu extrahieren.
Typen
Filterkaffeemaschinen
Pour-Over-Kaffeebereiter
Pour-Over-Kaffeebereiter sind manuelle Brühgeräte, die Kaffeeliebhabern eine bessere Kontrolle über den Brühvorgang ermöglichen. Der Grundaufbau besteht aus einem trichter- oder kegelförmigen Tropfer, der einen Papier- oder Metallfilter aufnimmt. Gemahlener Kaffee wird in den Filter gegeben und langsam und kontrolliert mit heißem Wasser übergossen.
Filterkaffeeautomaten
Automatische Filterkaffeemaschinen, auch Filterkaffeeautomaten genannt, sind beliebte elektrische Brühgeräte, die auf Komfort und Benutzerfreundlichkeit ausgelegt sind. Filterkaffeeautomaten automatisieren den Brühvorgang. Der Nutzer füllt nur Wasser in einen Behälter, gibt gemahlenen Kaffee in einen Filterkorb und schaltet die Maschine ein. Das Wasser wird erhitzt und dann über den Kaffeesatz getropft. Der gebrühte Kaffee fließt durch einen Filter in eine Kanne oder Karaffe, die auf einer Warmhalteplatte steht, um den Kaffee heiß zu halten. Einige Modelle bieten Funktionen wie einstellbare Brühstärke und Zeitverzögerung.
Brühkaffeemaschinen
Cold Brew Kaffeemaschinen
Cold Brew Kaffeemaschinen sind Geräte zur einfachen und effizienten Zubereitung von Cold Brew Kaffee. Dabei werden grob gemahlene Kaffeebohnen in der Regel über einen längeren Zeitraum, üblicherweise für 12 bis 24 Stunden, in kaltem Wasser oder Wasser mit Raumtemperatur eingeweicht. Das Ergebnis ist ein mildes, weniger saures Kaffeekonzentrat, das vor dem Verzehr mit Wasser oder Milch verdünnt werden kann. Diese Maschinen verfügen oft über ein Filter- oder Siebsystem zur Trennung des Kaffeesatzes, was den Brühvorgang bequem und sauber macht.
French Presses
Eine French Press ist ein einfaches und effektives Gerät zur Kaffeezubereitung. Es besteht aus einem zylindrischen Glas- oder Edelstahlbehälter mit einem Kolben und einem Metallnetzfilter. Zur Kaffeezubereitung werden grob gemahlene Kaffeebohnen in der Presse in heißes Wasser eingeweicht. Nach einigen Minuten wird der Kolben nach unten gedrückt und trennt so den Boden vom gebrühten Kaffee. Diese Methode ermöglicht eine vollmundige und aromatische Tasse, da der Kaffeesatz während des Brühvorgangs in direktem Kontakt mit dem Wasser bleibt.
Türkische Kaffeebereiter
Türkische Kaffeebereiter, auch bekannt als Cezve oder Ibrik, sind traditionelle Brühgefäße für die Zubereitung von türkischem Kaffee. Diese kleinen Töpfe bestehen typischerweise aus Kupfer oder Messing und haben einen langen Griff und einen breiten Boden. In der Cezve werden fein gemahlener Kaffee, Wasser und optional Zucker vermischt und auf kleiner Flamme erhitzt. Bei dem einzigartigen Brühverfahren wird die Mischung mehrmals fast zum Sieden gebracht, wodurch ein starker, konzentrierter Kaffee mit einem dicken Schaum entsteht, der als „Kaymak“ bekannt ist. Der fein gemahlene Kaffeesatz setzt sich am Boden ab und sorgt für ein unverwechselbares und reichhaltiges Kaffeeerlebnis.
Druckbasierte Kaffeemaschinen
AeroPress
Die AeroPress ist ein kompakter Kaffeebereiter, der auf Einfachheit und Vielseitigkeit ausgelegt ist. Es besteht aus einer zylindrischen Kammer mit einem Kolben und einer Filterkappe. Um Kaffee zuzubereiten, geben Nutzer Kaffeesatz und heißes Wasser in die Kammer, rühren um, setzen den Filterdeckel auf und drücken den Kolben, um den Kaffee zu extrahieren. Ihr einzigartiges Design ermöglicht ein schnelles und einfaches Brühen und ist dafür bekannt, eine weiche und reichhaltige Tasse Kaffee mit Kontrolle über die Brühvariablen zu produzieren. Die AeroPress ist bei Kaffeeliebhabern wegen ihrer Tragbarkeit, Erschwinglichkeit und der Möglichkeit, mit verschiedenen Brühtechniken zu experimentieren, beliebt.
Espressokanne/Moka Pot
Eine Espressokanne ist ein Gerät zur Zubereitung von Kaffee auf einem Kochherd. die starken und aromatischen Kaffee brüht, indem sie kochendes Wasser unter Dampfdruck durch gemahlenen Kaffee leitet. Es besteht aus einer unteren Kammer für Wasser, einem mittleren Trichter für Kaffeesatz und einer oberen Kammer für den fertigen Brühvorgang. Wenn sich das Wasser erwärmt, wird es durch den Druck durch den Kaffeesatz gepresst, wodurch ein reichhaltiger und konzentrierter Kaffee entsteht, der als Moka bekannt ist. Das Verfahren ist einfach, schnell und wegen seiner Fähigkeit beliebt, einen kräftigen Kaffee mit einem unverwechselbaren Geschmack zuzubereiten, der in gewisser Weise dem Espresso ähnelt.
Pod-/Padmaschinen
Pod-/Padmaschinen, auch bekannt als Portionskaffeemaschinen, sind kompakte, praktische Geräte zum Zubereiten einzelner Kaffeeportionen. Sie verwenden vorverpackte Kaffeepads oder -kapseln, sodass Nutzer schnell und einfach eine einzelne Tasse Kaffee mit minimalem Aufwand und Chaos zubereiten können. Diese Maschinen bieten eine Vielzahl von Kaffeeoptionen für unterschiedliche Geschmäcker und werden wegen ihrer Einfachheit und Zeiteffizienz geschätzt.
Siebträgerkaffeemaschinen
Siebträgerkaffeemaschinen, allgemein auch als Espressomaschine bekannt, sind spezielle Kaffeemaschinen, die dazu dienen, konzentrierten Kaffee zuzubereiten, indem heißes Wasser durch fein gemahlene Kaffeebohnen gepresst wird. Sie arbeiten unter hohem Druck, typischerweise etwa 9 Bar, um reichhaltige Aromen und aromatische Verbindungen aus dem Kaffeesatz zu extrahieren. Espresso zeichnet sich durch seinen kräftigen Geschmack und eine Schicht Crema, einen cremigen Schaum, aus. Diese Maschinen gibt es in verschiedenen Ausführungen, darunter manuelle, halbautomatische und automatische, und bieten dem Benutzer unterschiedliche Kontrolle über den Brauprozess.
Kaffeevollautomaten
Kaffeevollautomaten sind fortschrittliche Geräte, die den gesamten Kaffeezubereitungsprozess rationalisieren. Diese Maschinen erledigen alles vom Mahlen der Kaffeebohnen bis zum Brühen, sodass kein manueller Eingriff erforderlich ist. Nutzer können Faktoren wie Mahlgrad, Kaffeestärke und Getränkeart anpassen, da diese Maschinen eine Vielzahl von Getränken zubereiten können, darunter Espresso, Cappuccino, Latte und normalen Kaffee. Mit eingebauten Mühlen, automatischen Brühsystemen und Milchaufschäumern bieten sie Komfort und Konsistenz und liefern frisch gebrühten Kaffee mit minimalem Aufwand.
Perkolatoren
Perkolator-Kaffeemaschinen sind traditionelle Brühgeräte, die aus einer Kanne, einem Mittelrohr und einem perforierten Korb bestehen. Das Wasser in der Kanne wird erhitzt und der entstehende Druck drückt es durch das Rohr nach oben und über den Kaffeesatz im Korb. Anschließend fließt der gebrühte Kaffee zurück in die Kanne und es entsteht ein kontinuierlicher Kreislauf, bis die gewünschte Stärke erreicht ist. Perkolatoren waren in der Vergangenheit beliebt, wurden jedoch aufgrund unterschiedlicher Brühmethoden und Geschmackspräferenzen weitgehend durch Filterkaffeemaschinen ersetzt.
Siphon-Kaffeemaschinen
Siphon-Kaffeemaschinen, auch Vakuumbereiter genannt, nutzen eine optisch ansprechende und auf Physik basierende Brühmethode. Sie besteht aus zwei Kammern. In der unteren Kammer wird Wasser erhitzt, wodurch ein Dampfdruck entsteht, der das Wasser dazu zwingt, in die obere Kammer zu strömen, wo der Kaffeesatz abgelegt wird. Beim Ausschalten der Hitze wird der gebrühte Kaffee durch einen Vakuumeffekt zurück in die untere Kammer gesaugt. Durch diesen Prozess entsteht ein einzigartiger und aromatischer Kaffee mit einem weichen und reinen Geschmack, der die Aromen der Bohnen hervorhebt.
Zusätzliche Informationen
en de
100%
+3
und 3 weitere …
Hier starten ›
Seitenaufrufe:
Letzte 24 Stunden: 98
Letzte 7 Tage: 564
Letzte 30 Tage: 2,889
Insgesamt: 193,093
