Einleitung
Use this guide to replace a dead or worn-out battery in your Apple Watch Series 9 (41mm) smartwatch. Look on the bottom of your watch to see what size you have.
Lithium-ion batteries have a limited lifespan. If your watch doesn't hold a charge or dies unexpectedly, it might be time to replace the battery.
If your battery is swollen, take appropriate precautions.
You'll need replacement screen and battery adhesive to complete this repair.
Was du brauchst
Attach and remove the watch bands as needed to get a better grip or stabilize your watch.
To remove a band, firmly press in the small, oval button on the underside of the watch and slide the band out of its groove.
Consider placing your watch on something soft like a clean cloth to help stabilize it and prevent damage.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Heat an iOpener and lay it on the screen for two minutes to soften its adhesive.
In diesem Schritt verwendetes Werkzeug:iFlex Opening Tool$11.99
Insert the iFlex at a downward angle between the bottom edge of the screen and frame.
With one hand, push down firmly on the watch's frame to secure it in place.
With your free hand, hold the iFlex and push the edges up to make it more rigid.
Pry up the screen enough for the iFlex to lay flat on its own.
Leave the iFlex inserted under the screen.
Keep the iFlex flat to maintain a gap between the screen and frame while inserting an opening pick.
Insert an opening pick between the screen and iFlex.
Remove the iFlex.
Slide the opening pick along the bottom edge to separate the adhesive securing it.
Slide the opening pick around the bottom left corner and up the left edge to separate the adhesive.
Slide the opening pick around the top left corner and along the top edge to separate the adhesive.
Slide the opening pick around the top right corner and stop at the top of the side button.
Insert the long edge of an opening pick between the left edge of the screen and frame.
Twist the pick to lift the screen and separate any remaining adhesive.
Pull the right edge of the screen over the digital crown.
Swing up the left edge of the screen so it's upright. The screen should be to the right of the digital crown.
This is a good point to plug in your watch and test all functions before sealing it up. Be sure to power it back down completely before you continue working.
Follow this guide to apply new screen adhesive and reseal your watch.
Heat an iOpener and lay it on the battery for two minutes to soften the adhesive.
Insert an opening pick between the bottom edge of the battery and frame.
Pry up the battery with the opening pick until it starts to separate from the frame.
Slide the pick farther under the battery and lift until all the adhesive is separated.
Lift and rotate the battery so its edge with the cable rests on the bottom edge of the watch.
During the remaining steps, keep the battery propped up against the bottom edge while you work.
In diesem Schritt verwendetes Werkzeug:Tweezers$3.99
Use one arm of angled tweezers to gently lift the tape from the top right corner of the battery.
Slide an opening pick under the battery cable to separate the adhesive.
Use the point of a spudger to lift the small, hinged locking flap on the battery ZIF connector.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$5.99
Remove the battery.
Use tweezers and a spudger to remove all the old adhesive from the battery recess.
If your replacement battery doesn't have adhesive pre-installed, put strips of thin, double-sided tape on the logic board (not directly on the battery) where the old adhesive was.
Insert the battery cable into its connector on the battery and lower the locking flap.
Remove any liners from the battery adhesive or double-sided tape.
Position the battery so the side with the cable connector is on the left edge of the watch.
Firmly press the battery into place to secure it with the adhesive.
For optimal performance, calibrate your newly installed battery after completing your repair.
