Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 Battery Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 Battery Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 Battery Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 weitere Personen haben diese Anleitung absolviert.
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
3 Kommentare zur Anleitung
Last I looked up for a different model there was a video..
pc2053 - Antwort
Hello,
My Dell Inspiron 13-7352 won't turn on; I was using it when there was power outage and I totally drained the battery and it went off automatically, after the power came back I charged it the whole night but it still totally doesn't turn on. I tried to long-press the power button but nothing happens. I am 99% sure that the reason was using it on battery until the whole charge was gone. Please help!
jobgondwe - Antwort
My Dell did the same thing. I followed the above instructions to remove the battery and then put it right back in. Plugged into power and wa-la...it powered up. So simple. Thanks.
pcoladeb - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 25,283
