Lenovo YOGA 730-15IKB Speaker Replacement
Einleitung
Zu Schritt 1 der AnleitungFollow this guide to replace the speakers in your Lenovo YOGA 730-15IKB.
Before replacing your speakers, make sure that you have ruled out any software audio issues. For example, make sure the volume is not muted and that the audio driver is installed.
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pry up the bottom cover with an opening tool.
Start at the front edge of the cover and make your way along the sides.
Disconnect the speaker cable by pulling the wire towards the front of the laptop.
Pull up on the left speaker to remove it from the chassis.
Do not fully remove the left speaker at this point. Notice that the left and right speakers are still connected by a wire.
Remove the red and black wire near the front of the laptop from underneath the hooks that hold it in place.
