Zum Hauptinhalt wechseln
The Garmin Vivoactive is a GPS smartwatch that includes sports apps for tracking activities, notifications, calories, and sleep. This watch incorporates features for both active and working environments.
Why isn’t the touchscreen working?
The screen freezes and becomes unresponsive to the touch.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 8
7 Kommentare
this is the solve problem
هذا هو حل المشكلة
قم بتحميل هذا الروم للمطور الرائع mugurete
https://drive.google.com/open?id=0B_hRh3...
von
I flash this to my smart watch but touchscreen isn't working.
von
I left mine on the radiator for 5 min and seems to be working... for now.
von
It's not working because it's a $25.99 watch mine broke 2 days after I bought it.
von
Chris Allen, your answer is really helpful. thank you very much for your insight and wisdom.
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
This could be a simple problem with a simple fix. First make sure the device is clean and free of dirt and dust. This is the most likely reason the touchscreen isn’t functioning properly. If the device is clean and still is unresponsive, perform a touchscreen-free factory reset of the device detailed in the troubleshooting guide. If a factory reset is unsuccessful, the screen may need to be replaced. Visit this Troubleshooting Page for help with the above and more answers.
War diese Antwort hilfreich?
Bewertung 6
3 Kommentare:
Just opened mine and none of the touch screen works
von
My watch screen turn white , so i dont know how to fix it
von
just opened mien and screen wont even work
von
will a factory re-set remove all of the data I've already recorded?
Bewertung 1
3 Kommentare:
It honestly hurts how painfully stupid your comment is.
von
Be fair - sometimes a "factory reset" may not be all it seems. That has become a well-worn term that sometimes means what it says, and sometimes is a bit of a reboot flushing some - but not all - data. It depends on the device and what exactly the "reset" does.
von
If you force the watch off by holding the power button, it does not erase any data. If you hold the right button while powering it back on it will.
von
3 day old vivoactive hr touchscreen not working?
Bewertung 1
2 Kommentare:
The vivoactive HR is different than the vivoactive. If the touch screen stops working on it and there is no damage to the display, it is most likely a calibration issue. Just reboot the watch by holding the left button 20 to 30 seconds or till the screen goes black. Then release the button and hold it for a second or two to turn it back on. When the watch turns back on it displays Garmin and calibrates the screen. Do not touch it while it says Garmin.
von
Thank you! This was so frustrating. Reset worked! Garmin did not show though.
von
Just got mine and the touch screen stopped working
Bewertung 1
I bought an hour before 3 months. After swimming in the pool right button for more options does not work, while the left buttom and touchscreen work. What should I do?
Bewertung 0
1 Kommentar:
I have the same problem, could you fix it?
von
from where can i get the spare touch screen for my broken smartwatch
Bewertung 0
1 Kommentar:
from where can i get replacement
von
Antwort hinzufügen
Tessa Gunnin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 131
Insgesamt: 131,459
