Zum Hauptinhalt wechseln
Latest vacuum sealer from FoodSaver, released late 2015. Contains an accessory hose, PulseVac button, and multiple settings based on food consistency.
How do I remove the dip tray?
The dip tray is full. How do I remove it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
As shown on our troubleshooting page, on the bottom front edge of the machine, pull on the handle to pull out the dip tray. Then, you will see where the liquid is stored. Carefully take out the tray and rinse it. Before putting it back into place, ensure that it is completely dry. Your FoodSaver should now vacuum the air out of a bag.
War diese Antwort hilfreich?
Bewertung 0
5 Kommentare:
How do you take out the tray. It doesn't lift out,
von
Same here! They must have forgot to put the "gray release buttons "on
von
Same problem! Anybody find a way to clean the tray?
von
Same problem!! Can't find any info on the internet
Nov 20, 2023 by tcruz
von
I had the same problem with my V5860 - then I found 2 levers on the underside of the machine which had to be pressed in while pulling on the tray.
By doing that, the tray slid out.
Good luck!
von
Antwort hinzufügen
Matt Ryan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 62
Insgesamt: 9,128
