Zum Hauptinhalt wechseln
Reparaturanleitungen, Handbücher und Hilfe bei der Fehlersuche für Apple LED Cinema Display 27". Hier findest du alles, was du für deine Apple LED Cinema Display 27" Reparatur brauchst.
Could I make my own glass?
I just bough an apple cinema monitor for a steal of a $160(No Glass), I was thinking about making my own glass in acrylic is that possible? It shouldn't be to hard because the glass is connected to the display by magnets, so I could just glue metal on to the back.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
N T I cannot see any reason why that would not work. It may be not quite as aesthetic but should still be functional. Post some images when done so we can see what you came up with.
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
K, just ordered the k plexiglass. Hopefully it goes well ;)
von
@oldturkey03 Okay so i just found a red pixel on my lcd and im bawling now, is there a way to fix this? Is this a dead pixel or a stuck pixel?
von
Depends on if the pixel is 'stuck' or 'dead'. the dead pixel is effectively a failed LED, whereas a 'stuck' pixel is one that cannot change colour.
Try running this process to see if it is just stuck. it effectively rapidly flashes through colours in the attempt to release it and cause it to change colour as it should.
if this doesn't work, then its a dead pixel, and cannot be fixed.
http://www.jscreenfix.com
von
Antwort hinzufügen
N T wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 125
