Zum Hauptinhalt wechseln
The Lenovo ThinkPad X1 Carbon 2nd Gen is the second generation of Lenovo's X1 series ultrabook.
8 Fragen Alle anzeigen
No backlight with blown fuse under lvds connector
Good day
i have thinkpad x1 gen2 with black screen, i can see faint image with torch and external display works fine, i disassemble it and saw a blown fuse under lvds connector on main-board, i replaced it with same fuse and it blown right away after single test, there is an 8pin IC next to the fuse which i believe to be for black-light or something which is not good i think, i want to replace it but i can not read its number so i can order it, will someone help me identify this IC,
https://ibb.co/bGjPe6
https://ibb.co/mz0msR
Thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
I found Fuse 1 blown replaced it .
the Fuse is on the opposite side of the motherboard where the screen connector to motherboard is , it is covered in sticky protective plastic.
unfortunately to me the laptop stopped powering on something else has happened to it that I could not fined yet.
Power starts green light flashes then the fan starts then power off follows
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
On my X1 carbon gen3 it says F:2B on that IC.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Thanks alot Jarlvik, Yes it is F:2B but just cannot find it anywhere on internet. Greets
von
Antwort hinzufügen
Khizar Hayat wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 16
Insgesamt: 3,017
