Zum Hauptinhalt wechseln
Der Dyson v6 Absolute ist ein kabelloser Staubsauger ohne Staubbeutel, der im September 2014 auf den Markt kam. Er verfügt über ein HEPA Filtersystem gegen Allergene. Er kann auf allen Böden benutzt werden und wiegt rund 2,1 Kilo. Er hat die Modellnummer SV09.
19 Fragen Alle anzeigen
Vacuum does not hold charge
Dyson V6 Absolute after being on charge for 24 hours only runs for about 15 seconds when you use it, how can this be fixed?
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Hi john7291
What is the frequency do you use it? everyday ? and how long it is with you?
What other options had you tried?
You mentioned that only 15 Seconds and it went flat, did you try charging again and test like maybe after one hour of charge.
von
Einen Kommentar hinzufügen
3 Antworten
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner’s battery life is not long enough to complete a vacuuming task, see the Dyson v6 Absolute Battery Life Is Too Short problem page for possible causes and solutions.
War diese Antwort hilfreich?
Bewertung 0
Unfortunately , the answer is to buy a new one. I'm quite the techy kind of girl and I completely dismantled my vacuum every screw every seal everything that could be removed. I did a spit shine and polish and still nada. So I ordered a new battery and charger. Voila, it worked....for another year.Now it lasts 10 seconds turns off and readily turns back on for increments of 3 sec. It will keep turning on indefinitely for 3 sec each time so the battery is not dead. Again Ive disassembled the entire machine. Nothing is stuck, nothing is plugged. Its cleaner inside than when I bought it. I'm NOT investing another $100 in a new battery. I'm investing in a Bissell stick, a name wayyyy older than Dyson
Bewertung 0
I cleaned the filter and then it worked perfectly!
Bewertung 0
Antwort hinzufügen
john7291 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 2,793
