Zum Hauptinhalt wechseln
Google Pixel 8 Pro Earpiece Speaker Replacement
Was du brauchst
  1. Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Prepare your Pixel for disassembly: Schritt 1, Bild 3 von 3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: Schritt 2, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: Schritt 2, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Mark your opening picks: Schritt 2, Bild 3 von 3
    • You'll be using opening picks to separate the screen from the frame. If inserted too far, a pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the bottom edge adhesive: Schritt 3, Bild 1 von 1
    • Adhesive and clips secure the screen to the frame. Heating the screen softens the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the screen for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate—but be careful as extreme heat can damage the screen and/or battery.
  4. Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: Schritt 4, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: Schritt 4, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Secure the Anti-Clamp: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Clamp
    $24.95
    Kaufen
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place your phone screen side up on an object so it will rest level between the Anti-Clamp's arms—the bottom edge should be hanging off.
    • Slide the arms over the left edge of your phone, so you have access to the bottom edge.
    • Position the suction cups as close to the center of the bottom edge as possible.
    • Squeeze the cups together to create suction.
  5. Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: Schritt 5, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: Schritt 5, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Twist the handle: Schritt 5, Bild 3 von 3
    • Pull the handle forward to lock the arms.
    • Turn the handle clockwise one full turn (360 degrees), or until the suction cups begin to stretch.
    • As the cups stretch, make sure they stay aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
  6. Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 6, Bild 3 von 3
    • Wait one minute for a gap to form between the screen and frame.
    • If the adhesive doesn't separate, twist the handle clockwise one quarter turn and wait another minute. Apply more heat if the screen cools down.
    • Insert an opening pick into the gap.
    • Don't insert your opening pick more than 3 mm to avoid damaging the spring contacts.
    • Pull the blue handle backwards to unlock the arms and remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  7. Google Pixel 8 Pro Earpiece Speaker Replacement, Apply a suction cup: Schritt 7, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Apply a suction cup: Schritt 7, Bild 2 von 2
    • Apply a suction handle to the center of the screen's bottom edge.
  8. Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 8, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 8, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Insert an opening pick: Schritt 8, Bild 3 von 3
    • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
    • If you're having trouble creating a gap, apply more heat and try again.
  9. Google Pixel 8 Pro Earpiece Speaker Replacement, Prevent damage to your phone: Schritt 9, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Prevent damage to your phone: Schritt 9, Bild 2 von 2
    • To avoid damaging your phone, don't insert your pick more than 3 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
  10. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 10, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 10, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the bottom edge adhesive: Schritt 10, Bild 3 von 3
    • Slide the opening pick along the bottom edge to separate the adhesive securing it.
    • Leave the pick in the bottom right corner to prevent the adhesive from resealing.
  11. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the right edge adhesive: Schritt 11, Bild 1 von 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  12. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: Schritt 12, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: Schritt 12, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the right edge adhesive: Schritt 12, Bild 3 von 3
    • Insert a second opening pick under the bottom right corner of the screen.
    • Slide the new pick to the top right corner to separate the adhesive securing the screen's right edge.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  13. Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: Schritt 13, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: Schritt 13, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Leave a pick in the bottom left corner: Schritt 13, Bild 3 von 3
    • Insert a third opening pick under the bottom edge of the screen.
    • Slide the new pick to the bottom left corner.
    • Leave the pick in the bottom left corner to prevent the adhesive from resealing.
  14. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the left edge adhesive: Schritt 14, Bild 1 von 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  15. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 15, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 15, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the left edge adhesive: Schritt 15, Bild 3 von 3
    • Insert a fourth opening pick under the bottom left corner of the screen.
    • Slide the new pick to the top left corner to separate the adhesive securing the screen's left edge.
    • Leave the pick in the top left corner to prevent the adhesive from resealing.
  16. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the top edge adhesive: Schritt 16, Bild 1 von 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  17. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the top edge adhesive: Schritt 17, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the top edge adhesive: Schritt 17, Bild 2 von 2
    • Insert a fifth opening pick under the top edge of the screen, near the left corner.
    • Slide the opening pick to the top right corner to separate the adhesive securing the screen's top edge.
  18. Google Pixel 8 Pro Earpiece Speaker Replacement, Prop up the screen: Schritt 18, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Prop up the screen: Schritt 18, Bild 2 von 2
    • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cable.
    • Swing up the right edge of the screen like the front cover of a book.
    • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
    • Prop up the screen so you can access the screen cable without straining it.
  19. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: Schritt 19, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: Schritt 19, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the screen cable cover: Schritt 19, Bild 3 von 3
    • Use an opening tool to pry up the upper edge of the screen cable cover.
    • Remove the cover.
  20. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: Schritt 20, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: Schritt 20, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the screen: Schritt 20, Bild 3 von 3
    • Insert the point of a spudger under the top right corner of the screen's press connector.
    • Gently pry up and disconnect the cable.
    • Remove the screen.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  21. Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 21, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 21, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 21, Bild 3 von 3
    • If you're installing a new screen with pre-installed adhesive, follow this step during reassembly. Otherwise, follow this guide to apply adhesive to your old screen.
    • Use the pull tabs to remove the liners covering the front camera cutout, the back of the screen, and the perimeter adhesive.
    • Reconnect the screen cable and reinstall its cover.
    • This is a good point to test your phone before sealing it up. Temporarily power on your phone and make sure it works as expected. Power it down before continuing.
    • Firmly press the screen into place on the frame—you should feel the clips "pop" into place.
    • Press firmly around the perimeter of the screen to secure it with the new adhesive.
    • Optionally, you can strengthen the adhesive bond by applying pressure evenly to the phone.
    • Follow this guide to calibrate the fingerprint sensor.
  22. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the 5G mmWave antenna: Schritt 22, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the 5G mmWave antenna: Schritt 22, Bild 2 von 2
    • The next few steps show how to disconnect and detach the 5G mmWave antenna cable. If your phone doesn't have a 5G mmWave antenna, skip the next four steps.
    • Be very careful not to scrape off or damage any surface mounted components during this step.
    • Insert the tip of a spudger under the top edge of the 5G mmWave antenna's press connector.
  23. Google Pixel 8 Pro Earpiece Speaker Replacement, Heat the 5G mmWave antenna adhesive: Schritt 23, Bild 1 von 1
  24. Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: Schritt 24, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: Schritt 24, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Separate the 5G mmWave antenna adhesive: Schritt 24, Bild 3 von 3
    • Insert the flat end of a spudger between the bottom of the 5G mmWave antenna cable and the midframe, just above the press connector.
    • Twist the spudger to separate the bottom of the cable from the midframe.
  25. Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: Schritt 25, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: Schritt 25, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Peel up the 5G mmWave antenna: Schritt 25, Bild 3 von 3
    Tesa 61395 Tape
    $5.99
    Kaufen
    • Grip the bottom of the 5G mmWave antenna cable and gently peel it from the midframe.
    • During reassembly, press the cable back into place on the midframe to secure it with the old adhesive. If it doesn't stick, use thin, double-sided tape to secure it.
  26. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: Schritt 26, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: Schritt 26, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the graphite tape: Schritt 26, Bild 3 von 3
    • A large graphite sheet must be removed and replaced to complete this repair. It connects the upper part of the battery, midframe, and the rear cameras.
    • Insert the point of a spudger under different parts of the graphite sheet and lift until you can grip the sheet with your fingers.
    • The sections of graphite sheet between the rear cameras and the battery will most likely tear. If they do, grip the broken part of the sheet and remove that section.
    • Peel up and remove the entire graphite sheet.
    • During reassembly, do not reuse the old graphite sheet. Follow this guide to replace the sheet.
  27. Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: Schritt 27, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: Schritt 27, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Move the USB‑C cover tape: Schritt 27, Bild 3 von 3
    • Use the tip of a spudger to gently lift the plastic shim that runs along the top of the USB-C port cover.
    • Remove the shim and set it aside or move it out of the way so you can access the USB-C port cover screws.
  28. Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 28, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 28, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Reassembly information: Schritt 28, Bild 3 von 3
    • During reassembly, follow this step to replace the plastic shim that runs across the bottom of the midframe and loudspeaker. If you don't have a replacement, press the old one back into place.
    • Remove the larger rectangular liner from the shim.
    • Place the shim so the smaller piece of foam lines up with the bottom of the USB-C port cover.
    • Use the flat end of a spudger to firmly press down along the whole shim to secure it.
    • Remove the remaining liner.
  29. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: Schritt 29, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: Schritt 29, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the USB‑C port cover: Schritt 29, Bild 3 von 3
    FixMat
    $36.95
    Kaufen
    • While the Pixel 8 Pro uses Torx Plus screws, standard Torx bits will also work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the USB‑C port cover.
    • Remove the cover.
  30. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the midframe: Schritt 30, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the midframe: Schritt 30, Bild 2 von 2
    • Use a T3 Torx screwdriver to remove the seven 5 mm‑long 3IP Torx Plus screws securing the midframe.
  31. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: Schritt 31, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: Schritt 31, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the midframe: Schritt 31, Bild 3 von 3
    • Remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
  32. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the battery: Schritt 32, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the battery: Schritt 32, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the battery cable press connector.
  33. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the front camera: Schritt 33, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the front camera: Schritt 33, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the front camera press connector.
  34. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the front camera: Schritt 34, Bild 1 von 1
    • Remove the front camera.
  35. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: Schritt 35, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: Schritt 35, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the rear camera assembly: Schritt 35, Bild 3 von 3
    • Use the point of a spudger to pry up and disconnect all three rear camera press connectors from the top edge of the logic board.
  36. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: Schritt 36, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: Schritt 36, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the rear camera assembly: Schritt 36, Bild 3 von 3
    • You may need to hold the 5G mmWave antenna cable out of the way while removing the rear camera assembly screws.
    • Use a T3 Torx screwdriver to remove the two screws securing the rear camera assembly:
    • One 3.5 mm‑long 3IP Torx Plus screw securing the top left corner
    • One 5 mm‑long 3IP Torx Plus screw securing the top right corner
  37. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: Schritt 37, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: Schritt 37, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the rear camera assembly: Schritt 37, Bild 3 von 3
    • Insert a spudger between the right edge of the rear camera assembly and frame.
    • Pry the rear camera assembly up and remove it.
  38. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: Schritt 38, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: Schritt 38, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: Schritt 38, Bild 3 von 3
    $3.99
    Kaufen
    • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the top left corner of the logic board.
    • Gently lift straight up to disconnect the cable.
    • To reconnect the cable, hold it in place over its socket and press down with the flat end of a spudger—the connector should snap into place. Don't try to force the connector into the socket. Reposition it and try again.
  39. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the 5G mmWave antenna bracket: Schritt 39, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the 5G mmWave antenna bracket: Schritt 39, Bild 2 von 2
    • Use a T3 Torx screwdriver to remove the two 5 mm‑long 3IP Torx Plus screws securing the 5G mmWave antenna bracket.
  40. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: Schritt 40, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: Schritt 40, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna bracket: Schritt 40, Bild 3 von 3
    • Insert the tip of a spudger in one of the 5G mmWave antenna bracket's screw holes.
    • Pry up with the spudger to dislodge the bracket.
    • Remove the bracket.
    • During reassembly, insert the bracket at a downward angle so the spring contacts and foam pads press up against the 5G mmWave antenna. Press the bracket down to secure it.
  41. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna: Schritt 41, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the 5G mmWave antenna: Schritt 41, Bild 2 von 2
    • Grab the 5G mmWave antenna cable and gently lift the antenna out of its recess.
    • If the cable disconnects from the antenna, don't worry! Use your fingers to remove the antenna. Make sure to reconnect the antenna cable during reassembly.
  42. Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: Schritt 42, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: Schritt 42, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: Schritt 42, Bild 3 von 3
    • Gently pull the black antenna cable out of its clips on the left edge of the phone and the daughterboard.
    • During reassembly, use the point of a spudger to gently push the cable back into its clips.
  43. Google Pixel 8 Pro Earpiece Speaker Replacement: Schritt 43, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement: Schritt 43, Bild 2 von 2
    • Gently move the black antenna cable out of its cutout on the bottom right corner of the daughterboard.
    • During reassembly, make sure the cable goes back into the cutout. If it doesn't, it may get damaged when you reinsert the rear camera assembly.
  44. Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker: Schritt 44, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Unfasten the earpiece speaker: Schritt 44, Bild 2 von 2
    • Use a T3 Torx screwdriver to remove the 3.5 mm‑long 3IP Torx Plus screw securing the earpiece speaker.
  45. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 45, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 45, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the earpiece speaker: Schritt 45, Bild 3 von 3
    • Insert the flat end of a spudger under the center of the earpiece speaker's bottom edge.
    • Pry the speaker up and remove it.
    • This may take some force. You'll hear a "pop" when the speaker is dislodged.
    • During reassembly, insert the edge of the speaker with an orange gasket at a downward angle into its recess. Then press down firmly on the speaker until it clicks into place.
  46. Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: Schritt 46, Bild 1 von 2 Google Pixel 8 Pro Earpiece Speaker Replacement, Disconnect the antenna cable: Schritt 46, Bild 2 von 2
    $3.99
    Kaufen
    • Insert one arm of a pair of angled tweezers under the metal neck of the black antenna cable coaxial connector, located on the bottom of the earpiece speaker.
  47. Google Pixel 8 Pro Earpiece Speaker Replacement, Unclip the antenna cable: Schritt 47, Bild 1 von 1
    • Unclip the antenna cable from its metal clip that sticks out from the speaker.
  48. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: Schritt 48, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: Schritt 48, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable tape: Schritt 48, Bild 3 von 3
    • Lift the antenna cable out of its groove in the earpiece speaker to separate the yellow tape securing it.
    • Use tweezers or your fingers to remove the yellow tape.
  49. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna cable: Schritt 49, Bild 1 von 1
    • Pull the antenna cable out of its groove and remove it.
  50. Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: Schritt 50, Bild 1 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: Schritt 50, Bild 2 von 3 Google Pixel 8 Pro Earpiece Speaker Replacement, Remove the antenna board: Schritt 50, Bild 3 von 3
    Tesa 61395 Tape
    $5.99
    Kaufen
    • Light adhesive secures the L-shaped antenna board to the bottom of the earpiece speaker.
    • Use a spudger to pry the antenna board off the earpiece speaker.
    • Remove the board.
    • During reassembly:
    • Before securing the antenna board to the speaker, make sure the board is oriented so the antenna socket is along the same edge as the cable groove.
    • If your replacement speaker has adhesive pre-installed, remove the plastic liner and press the board into place to secure it with the adhesive.
    • If your replacement speaker doesn't have pre-installed adhesive, use thin double-sided tape such as Tesa Tape to secure the board to the speaker.
  51. Google Pixel 8 Pro Earpiece Speaker Replacement, You're left with the earpiece speaker: Schritt 51, Bild 1 von 1
    • You're left with the earpiece speaker.
Abschluss
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
55.149 Reputation
408 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.410 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 27
Letzte 30 Tage: 100
Insgesamt: 624
