Zum Hauptinhalt wechseln
Microsoft Surface Laptop 3 15" Battery Replacement
Was du brauchst
  1. Microsoft Surface Laptop 3 15" Battery Replacement, Prepare your device: Schritt 1, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Prepare your device: Schritt 1, Bild 2 von 2
    • Turn on your laptop and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power down your laptop and unplug any cables.
    • Close the laptop.
  2. Microsoft Surface Laptop 3 15" Battery Replacement, Flip the laptop over: Schritt 2, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Flip the laptop over: Schritt 2, Bild 2 von 2
    • Flip the laptop over and place it on your work surface, feet facing up.
  3. Microsoft Surface Laptop 3 15" Battery Replacement, Removal tip: Schritt 3, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Removal tip: Schritt 3, Bild 2 von 2
    • The feet on the bottom of the laptop are meant to be removed with the pointed end of a spudger.
    • Each foot has a hidden indent that will simplify removal.
    • To make sure the spudger is in the indent, insert it at the nearest long edge, pushing parallel to the short edges of the laptop, as shown.
    • Note that the two feet near the rear (screen) edge are different than the two front feet.
  4. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: Schritt 4, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: Schritt 4, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the rear feet: Schritt 4, Bild 3 von 3
    • Insert the pointed end of a spudger underneath one of the two rear feet, at its rear edge.
    • Push the spudger underneath the foot and pry up to release it.
    • The two rear feet are secured with some light adhesive.
    • Repeat to remove the second rear foot.
  5. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: Schritt 5, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: Schritt 5, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the front feet: Schritt 5, Bild 3 von 3
    • Insert the pointed end of a spudger underneath one of the two front feet, at its front edge.
    • The two front feet are secured with plastic clips as well as light adhesive.
    • Repeat to remove the second front foot.
  6. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 6, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 6, Bild 2 von 2
    • During reassembly:
    • Note that the front and rear feet are different.
    • Note that the front feet are directional and only clip in one way.
  7. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 7, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 7, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 7, Bild 3 von 3
    • In place of reusing old, worn out feet on your device, 8 mm rubber furniture pads can be a good substitute.
    • Peel a pad away from its backing, align it over a foot cavity, and press to secure.
  8. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case screws: Schritt 8, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    Kaufen
    • Use a T5 Torx driver to remove the four 3 mm screws in the foot cavities securing the upper case to the device.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your laptop.
    • During reassembly, don't over-tighten these screws—they strip easily.
  9. Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: Schritt 9, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: Schritt 9, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Open the display: Schritt 9, Bild 3 von 3
    • Flip the device over.
    • Open the display as far as it will go.
  10. Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: Schritt 10, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: Schritt 10, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Lift up the upper case: Schritt 10, Bild 3 von 3
    • The upper case is secured in place by magnets.
    • Grip the top edge of upper case above the keyboard and lift straight up to release it.
    • Don't try to completely remove the upper case just yet, as it's still connected to the rest of the laptop.
    • Lift the front edge of the upper case up and away from the laptop, taking care to not strain the keyboard and touchpad ribbon cable underneath.
    • During reassembly, lower the upper case onto the lower case until the magnets snap into place and it lays flat.
    • Check that the upper case sits flush around the entire perimeter. Any gaps between the upper and lower case near the display could cause damage to the display as it closes.
  11. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: Schritt 11, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: Schritt 11, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the ribbon cable: Schritt 11, Bild 3 von 3
    • The keyboard and touchpad ribbon cable is secured in place by a magnet connector.
    • On some models, this connector is surrounded by black tape.
    • Insert the flat end of a spudger underneath one edge of the ribbon cable connector, and pry up to release it.
    • Remove the ribbon cable from the motherboard.
  12. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case: Schritt 12, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the upper case: Schritt 12, Bild 2 von 2
    • Remove the upper case.
    • Set the upper case onto a clean surface, keyboard-side down.
    • Ensure the ribbon cable lays flat, and isn't twisted or stressed.
  13. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD screw: Schritt 13, Bild 1 von 1
    • Use a T5 Torx driver to remove the 2.7 mm screw securing the SSD.
    • Removing the SSD also functions as a battery disconnect and should be performed before all major repairs.
  14. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD: Schritt 14, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the SSD: Schritt 14, Bild 2 von 2
    • With the SSD screw removed, the SSD will pop up at a shallow angle.
    • Grip the end of the SSD and pull it away from its board connector to remove it.
    • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
  15. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: Schritt 15, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: Schritt 15, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the tape: Schritt 15, Bild 3 von 3
    Kaufen
    • Use a pair of tweezers to remove the two pieces of black tape covering the bottom left and bottom right corners of the motherboard.
    • During reassembly, if the tape is sticky enough to be reused, reapply it.
  16. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: Schritt 16, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: Schritt 16, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink shield: Schritt 16, Bild 3 von 3
    • Use an opening tool to pry up the front edge of the metal shield covering the heatsink.
    • Try not to deform the shield too much—you'll need to reinstall it during reassembly.
  17. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 17, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 17, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 17, Bild 3 von 3
    • Work your way around the perimeter of the shield, prying up intermittently, until you can remove it completely.
  18. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 18, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 18, Bild 2 von 2
    • Remove the heatsink shield.
  19. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: Schritt 19, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: Schritt 19, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the cooling fan: Schritt 19, Bild 3 von 3
    • Use the pointed end of a spudger to flip up the locking flap on the fan cable's ZIF connector.
    • Use a pair of tweezers to pull the fan cable straight out of the connector.
  20. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink screws: Schritt 20, Bild 1 von 1
    • Use a T3 Torx driver to remove the ten screws securing the heatsink:
    • Two 2.5 mm screws
    • Three 2.0 mm screws
    • One 3.0 mm screw
    • Two 4.1 mm screws
    • Two 3.4 mm screws
  21. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 21, Bild 1 von 1
    • Align the heatsink with the centering peg on the motherboard.
    • Tighten the four CPU tension screws in an "X" pattern.
  22. Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: Schritt 22, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: Schritt 22, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Clear the alignment peg: Schritt 22, Bild 3 von 3
    • Use the tip of your finger to lift the far right edge of the heatsink up and off of the small alignment peg near the right side of the fan on the lower case.
    • Once the heatsink has cleared the peg, lightly pull the right edge towards the front of the device.
  23. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: Schritt 23, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: Schritt 23, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the heatsink: Schritt 23, Bild 3 von 3
    • Remove the heatsink.
    • If the heatsink feels stuck to the CPU, gently wiggle it side-to-side to separate it from the thermal paste holding it down.
    • Don't pull on the heatsink too hard; the heat pipes are susceptible to creasing.
  24. Microsoft Surface Laptop 3 15" Battery Replacement, Reapply thermal paste: Schritt 24, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reapply thermal paste: Schritt 24, Bild 2 von 2
    • Before reinstalling the heatsink, follow this guide to clean the heatsink and CPU and reapply thermal paste.
  25. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard shields: Schritt 25, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard shields: Schritt 25, Bild 2 von 2
    • Some motherboard screws are located under two of the metal shields, both of which need to be removed.
    • Use an opening tool to pry up an edge of the metal shield covering the right side of the motherboard.
    • Try not to deform the shield too much—you will need to reinstall it during reassembly.
    • Remove the shield.
  26. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 26, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 26, Bild 2 von 2
    • Repeat the previous step to remove the second shield from the left side of the motherboard, closest to the CPU.
  27. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: Schritt 27, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: Schritt 27, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the right speaker: Schritt 27, Bild 3 von 3
    • Use the pointed end of a spudger to lift and disconnect the right speaker wire from its connector on the motherboard.
  28. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: Schritt 28, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: Schritt 28, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the Surface Connect port: Schritt 28, Bild 3 von 3
    • Use an opening tool to flip open the gold locking arm on the Surface Connect port's motherboard connector.
  29. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 29, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 29, Bild 2 von 2
    • Grip the Surface Connect port cable and pull it away from its connector to remove it.
  30. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the left speaker: Schritt 30, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the left speaker: Schritt 30, Bild 2 von 2
    • Use the pointed end of a spudger to lift and disconnect the left speaker wire from its connector on the motherboard.
  31. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the display connector shields: Schritt 31, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the display connector shields: Schritt 31, Bild 2 von 2
    • Use an opening tool to pry up the black shield covering the right bank of display connectors.
    • Repeat at different points around the shield until it becomes loose.
  32. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 32, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 32, Bild 2 von 2
    • Repeat the previous step to remove the remaining shield from the left bank of display connectors.
  33. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the display cables: Schritt 33, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the display cables: Schritt 33, Bild 2 von 2
    • Use the flat end of a spudger to pry the first display cable up and out of its socket on the motherboard to disconnect it.
  34. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 34, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 34, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 34, Bild 3 von 3
    • Disconnect the three remaining display connectors.
  35. Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 35, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Reassembly tip: Schritt 35, Bild 2 von 2
    • During reassembly, use the flat end of a spudger to gently push the display cables back into their cavity in the lower case.
  36. Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: Schritt 36, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: Schritt 36, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Disconnect the antenna cable: Schritt 36, Bild 3 von 3
    Kaufen
    • Use a pair of tweezers to grip the antenna cable close to its base.
    • Pull straight up to disconnect the cable.
  37. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard bracket: Schritt 37, Bild 1 von 1
    • Use a T3 Torx driver to remove the two 3 mm screws securing the motherboard bracket.
  38. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 38, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 38, Bild 2 von 2
    • Use a pair of tweezers to remove the motherboard bracket.
  39. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard screws: Schritt 39, Bild 1 von 1
    • Use a T3 Torx driver to remove the six 2 mm screws securing the motherboard.
  40. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: Schritt 40, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: Schritt 40, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the motherboard: Schritt 40, Bild 3 von 3
    • Use your fingers to lift and remove the motherboard.
    • If the motherboard feels stuck, slide the motherboard to the right so the I/O ports clear their cutouts on the chassis.
    • Ensure the two screwpost braces underneath the motherboard don't get lost during removal.
  41. Microsoft Surface Laptop 3 15" Battery Replacement, Check cables during reassembly: Schritt 41, Bild 1 von 1
    • When you reinstall the motherboard, verify that no cables get trapped under the board as you lower it into place. Check each of the five locations carefully:
    • Four display cables
    • Antenna cable
    • Left speaker cable
    • Surface Connect cable
    • Right speaker cable
  42. Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery contact cable adhesive: Schritt 42, Bild 1 von 2 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery contact cable adhesive: Schritt 42, Bild 2 von 2
    • Heat an iOpener and lay it on top of the battery contact cable for about a minute, in order to soften the adhesive securing it to the case.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead.
  43. Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: Schritt 43, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: Schritt 43, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Separate the battery contact cable: Schritt 43, Bild 3 von 3
    • Slide an opening pick underneath the battery contact cable to separate it from the case.
    • If the adhesive is stubborn, don't force the pick. Lightly reheat the cable and try again.
    • During reassembly, note that the contact cable is centered in place with both a screwpost and an alignment peg.
  44. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery screws: Schritt 44, Bild 1 von 1
    • Use a T3 Torx driver to remove the six 2.7 mm screws securing the battery to the case.
  45. Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: Schritt 45, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: Schritt 45, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Loosen the battery adhesive: Schritt 45, Bild 3 von 3
    • Apply adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the top edges of all three battery cell groups.
    • If you are using adhesive remover, follow these preparation steps first.
    • Wait 2–3 minutes for the adhesive remover to penetrate and soften the adhesive before you proceed to the next step.
  46. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 46, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 46, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 46, Bild 3 von 3
    Plastic Cards
    $2.99
    Kaufen
    • Take care not to puncture or bend the battery with your tools—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Slide a plastic card underneath the far left battery cell group to slice through the adhesive holding it to the case.
    • If you encounter significant resistance at any point during this procedure, pause and apply more adhesive remover. Wait for it to soak into the adhesive, and try again.
    • Wiggle the card from side to side as you insert it under the battery cells to fully separate all adhesive holding them in place.
    • Leave the plastic card temporarily underneath the cell to prevent it from re-adhering while you continue.
  47. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 47, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 47, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 47, Bild 3 von 3
    • Slide a second plastic card underneath the middle battery cell group to slice through the adhesive holding it to the case.
  48. Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 48, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 48, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement: Schritt 48, Bild 3 von 3
    • Slide the card out from under the middle cell group.
    • Leave the card that's underneath the left group in place for now.
    • Slide the plastic card underneath the far right battery cell group to slice through the adhesive holding it to the case.
    • Leave the plastic card temporarily underneath the right cell group to prevent it from re-adhering while you continue.
  49. Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: Schritt 49, Bild 1 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: Schritt 49, Bild 2 von 3 Microsoft Surface Laptop 3 15" Battery Replacement, Remove the battery: Schritt 49, Bild 3 von 3
    Tesa 61395 Tape
    $10.99
    Kaufen
    • Use both plastic cards to lift the entire battery assembly up and away from the case.
    • If the battery still feels adhered to the case, reapply adhesive remover and use the plastic cards in problem areas to make sure all three cell groups are fully separated from the case.
    • Remove the battery.
    • During reassembly, double-check the fit and alignment of your new battery before sticking it down.
    • If your battery came with adhesive pre-installed on the bottom, flip it over and carefully peel away the liner to expose the adhesive. If your battery did not come with adhesive, apply a thin double-sided adhesive tape such as Tesa 61395 to keep your battery in place.
    • Carefully position the battery and set it into place. Press and hold each cell group firmly for 5–10 seconds to secure it to the lower case.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Carsten Frauenheim
114.833 Reputation
339 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.392 Anleitungen geschrieben
3 Kommentare
Wow, that was hard. but I did it and it worked. however. a couple of things. two of the mounting holes in the ifixit battery do not line up with the holes in the case - not a big deal, as the adhesive does most of the holding. And, two elongated dump-bell-shaped washers/bushings fell out somewhere when taking the motherboard out. I just found them lying in the case. I have no idea where they go (i can send an image of them).. like i said, it appears to work without them -- for now.
R
buckrepairer - Antwort
I'll check on those battery mounting holes! Those two washers are mentioned in step 40. They live under the motherboard.
Carsten Frauenheim -
Got through that. The author did a great job with the instructions, thank you!
The laptop powers up and operates just fine but is not charging. We have ordered another Surface 127W power supply but does anyone know of any issues with the Microsoft power supply not being happy with the replacement battery?
Patrick Arnold - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 26
Letzte 7 Tage: 130
Letzte 30 Tage: 690
Insgesamt: 22,852
