Zum Hauptinhalt wechseln
The snow is falling, and it's go time! GoPro time that is! Grab your boots, tighten your bindings, and strap on your helmets; this teardown is about to get gnarly.
Want to be kept up to date on the latest radical teardowns? Follow us on Twitter, or like us on Facebook to keep up with iFixit news.
Was du brauchst
Werkzeuge
Mehr anzeigen …
Dieser Teardown ist keine Reparaturanleitung. Um dein GoPro Hero3 zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. GoPro Hero3 Teardown, GoPro Hero3 Teardown: Schritt 1, Bild 1 von 2 GoPro Hero3 Teardown, GoPro Hero3 Teardown: Schritt 1, Bild 2 von 2
    • In addition to a sleeker design with more clearly-labeled buttons than the Hero2, the Hero3 is shredding some sick powder with the following specs:
    • White/Silver/Black Editions with video resolution up to 1080p30 (White/Silver) / 1080p60 (Black) and 4K (!) at 15 frames per second (fps) in the Black Edition.
    • 5/11/12 megapixel camera with 30/10/3 fps burst, respectively
    • 1050 mAh rechargeable lithium-ion battery
    • Up to 64 GB of external microSD storage
    • Built-in Wi-Fi
  2. GoPro Hero3 Teardown: Schritt 2, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 2, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 2, Bild 3 von 3
    • What is inside of you, small box of joy?
    • To our dismay, we could not examine the deep dark innards of the Hero3 through the lens. Time to crack it open!
    • Peeling off the water resistant port cover reveals the following ports:
    • Mini USB
    • Micro HDMI
    • microSD
    That's not microUSB but miniUSB.
    Dmitry Mikhailenko - Antwort
    Duly noted. Thanks for the heads-up!
    Fixed.
    Miroslav Djuric -
  3. GoPro Hero3 Teardown: Schritt 3, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 3, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 3, Bild 3 von 3
    • With the simple press of a button, the back cover is free, allowing access to—what's this—a battery pull tab?
    • It's almost as if the folks at GoPro wanted you to be able to take the battery out of your HD Hero3. What a novel idea.
    • The Hero3's 3.7 V battery is rated at 1050 mAh/3.85 Wh, a 50 mAh decrease from previous models, presumably due to the device's smaller size.
    • As usual, caution labels on the back of the battery warn us not to store the battery in high temperatures, disassemble it, or dispose of it…with fire.
    • Thanks for the heads up, GoPro.
  4. GoPro Hero3 Teardown: Schritt 4, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 4, Bild 2 von 2
    • It has come to that time in the teardown where we finally have to reach for a tool. Not just any tool, but the always-appropriate plastic opening tool.
    • A few clips and a little bit of adhesive are no challenge for our trained hands, and the front cover lifts right off.
    It's easier to lift of the front if the camera was running for some time right before the teardown.
    The heat produced by the components makes the glue a little less sticky…
    But don't forget to take out the battery!
    Kevin Schmitt - Antwort
    When removing the front cover, be cognizant that the LCD may want to come with the cover and will sever the ribbon cable if allowed to to so. Just push the screen itself back towards the body when popping the tabs. Totally not from personal experience...
    On an unrelated note, does anyone know where I can get a replacement front LCD+ribbon?
    Justin - Antwort
  5. GoPro Hero3 Teardown: Schritt 5, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 5, Bild 2 von 2
    • We are through the adhesive and on to some of our favorite little repair-friendly friends: Torx screws!
    • Four surprisingly-long (8.1 mm) T4 Torx screws hold the midframe in place, and are easily removed with the help of our 54 Bit Driver Kit.
    The torx are T3 and not T4
    Francesco Caveglia Beatris - Antwort
    T4 works OK for me?
    Chris Hall - Antwort
  6. GoPro Hero3 Teardown: Schritt 6, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 6, Bild 2 von 2
    • A little more prying, and the midframe and motherboard assembly is the next piece to practically fall off the GoPro. This is almost too easy.
    • We have always pushed for product design that favors repairability, but seeing it in action still makes us do a double take.
  7. GoPro Hero3 Teardown: Schritt 7, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 7, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 7, Bild 3 von 3
    • Two pieces of tape, one connector, four more screws, a little bit-o-prying…this device is coming apart pretty easily considering the small package and large recording ability!
    Where I can buy original lens for gopro hero 3 black for replacement?
    Thanks
    rabijki - Antwort
    Did u find any original lens for your gopro let me know thanks
    Karim Ghrayeb -
    ragecams carries all the replacement lenses:
    http://ragecams.com/shop/advanced_search...
    dennis -
  8. GoPro Hero3 Teardown: Schritt 8, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 8, Bild 2 von 2
    • The image sensor pops off the motherboard assembly and can be replaced independently of the rest of the ICs. This Hero is gaining repairability cred left and right.
    • Our Hero3 Black Edition comes with a 12 megapixel image sensor with improved low light capabilities, a step up from the 5 and 11 megapixel modules in its other Hero counterparts.
    • While more resolution is great for stills, the pixel-crunching power that sets the Black Edition's video skills apart from the rest of the pack are in the image processor—more on that later.
    Where can I get a front LCD screen? Mine is broken and I can´t get it here in Brazil!
    Thanks
    Ana Paula Mattos - Antwort
    ragecams carries all replacement parts for gopro:
    http://ragecams.com/shop/gopro-hero33-re...
    dennis -
    Great teardown!
    Do you know what that cable port between the CMOS and the main board is called? I just learned its called a Flat Flex Cable, but the question is what is that port called.
    I'd like to know if its possible to separate the sensor from the body.
    Daniel Allen - Antwort
    yes ragecams offers that cable
    www.ragecams.com
    dennis -
    Hi Daniel, were you able to find the cable? I'm also trying to take the CMOS and the lens away from the camera. I will appreciate any guidance!
    Piotr Miczek -
    Just wanted to say Thanks for the tutorial, easy peasy. Unfortunately the lens housing was to small on the receiving end. So i ended up replacing the lens instead of the entire housing.
    https://drive.google.com/open?id=12_EMqp...
    Charles Allen - Antwort
  9. GoPro Hero3 Teardown: Schritt 9, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 9, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 9, Bild 3 von 3
    • At the heart of the GoPro lies a Sony IMX117 image sensor.
    • According to our pals at Chipworks, the Exmor-R sensor features a "1.55 µm back illuminated design on a ceramic substrate"—cool!
    • The sensor supports 12 MP imaging at up to an impressive 35 fps, even though the camera advertises a burst rate of 30 fps.
    • Check out their teardown for even more info on the Hero3!
  10. GoPro Hero3 Teardown: Schritt 10, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 10, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Picks (Set of 6)
    • It's time for everyone's favorite segment: Science with iFixit! We decided to have a little bit of fun with the Hero3's lens and one of our iFixit Guitar Picks.
    • For this simple demonstration, we placed a guitar pick in front of the lens upside-down and looked through the glass. As you can see, the upside-down graphic has been flipped right-side up!
    • So, if the lens flips the image, why aren't all of the pictures from our digital cameras inverted?
    • Well, just like the lens of our eyeball, anything viewed through an optical lens appears upside-down until it's fed through a processor of some kind. For a digital camera, that processor is an integrated circuit. Our vision, on the other hand, utilizes the most advanced processor in the world to flip the image around: the human brain.
    Try taking a picture like that or when you are taking it apart just for fun! It would be cool to see cameras working while they are being disassembled.
    Lucas Hoekstra (Lucas9810) - Antwort
  11. GoPro Hero3 Teardown: Schritt 11, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 11, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 11, Bild 3 von 3
    • Another daughterboard flies off the main assembly; this time it's the microSD and accessory board.
    • If you've never used a GoPro, this large port might look pretty foreign to you. It's okay, you're not alone. The proprietary port is used for a variety of GoPro accessories, including a fold-out LCD attachment, extended battery, and various A/V adapters.
  12. GoPro Hero3 Teardown: Schritt 12, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 12, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 12, Bild 3 von 3
    • No new tricks here, either. Removing the motherboard requires no more than a spudger and a Phillips #0 screwdriver.
    • Most components in the Hero3 use very little power and generate minimal heat. This light coating of thermal compound on the image processor is the most aggressive cooling feature in the device.
  13. GoPro Hero3 Teardown: Schritt 13, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 13, Bild 2 von 2
    • Chips on the motherboard:
    • ChipSiP CT49248NS962D 1 Gb NAND flash + 4 Gb DDR3 SDRAM
    • Ambarella A770 camera system-on-a-chip
    • Austriamicrosystems AS3713 system PMU with backlight driver
    • Freescale Kinetis SCK20DN51Z USB controller
    • Qualcomm Atheros AR6233GEAM2D 802.11n + Bluetooth 4.0 controller
    • AC3029
    According to chipworks (and that part number)
    ChipSip CT49248DD962D 1 Gb NAND flash + 4 Gb DDR3
    which is right?
    turbosix - Antwort
    Thanks for catching that! We've updated that step with the proper identification.
    Andrew Optimus Goldheart -
    If the gopro has a bluetooth chip, why it does not use this mode of transmission? Or, is used, as is done this?
    danielgade - Antwort
    What is the AC3029 IC?
    gabrieldesjardins - Antwort
    who knows what the marking of the internal battery?
    luton - Antwort
    I would also like to know what type of internal button cell battery is being used in this camera.
    Jon Drews -
  14. GoPro Hero3 Teardown: Schritt 14, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 14, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 14, Bild 3 von 3
    • More tape, more screws, moar fun!
    • A few more Phillips screws stand in the way of pulling out the "ultra sharp ƒ/2.8 6-element aspherical glass lens."
    • Honestly, we just had a lot of fun looking at our guitar picks through this lens—here's another look through the Hero3's eye now that it's free of the motherboard.
    • Because why? Because science.
  15. GoPro Hero3 Teardown: Schritt 15, Bild 1 von 3 GoPro Hero3 Teardown: Schritt 15, Bild 2 von 3 GoPro Hero3 Teardown: Schritt 15, Bild 3 von 3
    Heat Gun
    $24.99
    • There are only a few components left around the device casing.
    • Last on the midframe is the LCD and its soldered-on cable. Repairability takes a hit here, when we have to pull out a heat gun and metal spudger to loosen the adhesive securing this cable to the midframe.
    • The rear case's last component is the button/speaker assembly which is attached to the backing of the battery compartment. A couple of screws and some tape hold it in place.
  16. GoPro Hero3 Teardown: Schritt 16, Bild 1 von 2 GoPro Hero3 Teardown: Schritt 16, Bild 2 von 2
    • GoPro HD Hero3 Repairability Score: 7 out of 10 (10 is easiest to repair)
    • The battery is intended to be easily replaced by the user, and requires no tools to access.
    • The entire device can be disassembled with readily-available tools.
    • Modular design throughout allows replacement of several individual components.
    • Minimal adhesive securing the front cover can be difficult to separate, but poses no real challenge to opening.
    • Fragile copper grounding tape can be difficult to peel and replace.
    • Because the display cable is adhered to the midframe, replacing the LCD requires use of a heat gun.
    Hi Andrew. I have this hero3 and was moding it to use different lenses when I accidentally cut the ribbon that connects the motherboard to the LCD screen! Am i hosed here or is that something I can order and replace myself? I understand Gopro won't repair cameras that don't qualify for warrenty issues. Any advice would be great! Thanks, Brad
    Brad - Antwort
    Same thing happened to me. Did you find a resolution to this or a replacement part?
    Eddie -
    Same thing just happened to me. Trying to replace the lens, took apart the GoPro Hero 3, ribbon was over heated and molded tightly around the side and wouldn't budge, severed it and now the lcd screen wont work and the camera wont turn on. Any ideas? Can't find this part.
    Charlie -
    Hi,
    was scratched my lens. gopro of course dont offer replacement. can You tell where I can buy lens for hero 3 black?
    rabijki - Antwort
    ragecams has all the correct gopro lenses and aftermarketlenses
    dennis -
    Hi , I will buy any broken Gopro hero 3 for $ 45.00 let me know if you are interested.
    Frank - Antwort
    How about a Hero 3+ Black, Frank?
    DougVG -
    Frank,
    Are you still buying broken Hero 3s? I have a broken 3 Black.
    Don
    jdmada -
    Frank
    I have a broken Gopro Hero3 black.
    Let me know if you buy it.
    Francisco Barahona -
    RageCams sells the lcd replacements now.
    dennis - Antwort
    But only for the hero 2! We are talking about the hero 3. Iam locking for such a part but cant find one anywhere. Sombody has an answer?
    Chris Blabla - Antwort
    There is a little copper grounding tape in the other side of the orage conector. If it breaks because of blending many times, how could I repair?
    Now, most of the times camera does not turn on, I must to press so hard near this zone to get it. I tried put a bit aluminum foil on the copper tape to make conduction but does not work.
    Javixu - Antwort
    have you solved your problem with the copper grouding? I seem to have the same problem!!
    sergiolopesfr -
    Hey, my gopro hero 3 black edition's buttons aren't working, only the power on/off/mode button is. I cant set the wifi on to control the cam from my iphone or remote... What should i do
    Alec Melkonian - Antwort
Jake Devincenzi
118.202 Reputation
57 Anleitungen geschrieben
65 Kommentare
Love it! Thanks for the take apart!!
coasttech - Antwort
Could you include a slide showing how to extract the lens from the lens housing? I would like to perform a lens mod, and I need to know if the lens comes out willingly or grudgingly.
sparky - Antwort
teardown video of the gopro lens change by RageCams
https://www.youtube.com/watch?v=_tUl-BzZ...
dennis -
Video of what needs to come apart to replace a lens.
https://www.youtube.com/watch?v=EHtanRrO...
Troy - Antwort
detailed lens change video by ragecams
dennis -
Would it be possible to remove the lense from the casing and mount it and have the box somewhere else and to record?
Nick Angelopoulos - Antwort
No, not a chance.
Bosco -
Where can I find a replacement for the USB port daughterboard. My go pro usb port is broken and ive lost the lose port. :(
powermaxums - Antwort
you would need a new motherboard. RageCams carries those:
http://ragecams.com/shop/gopro-replaceme...
dennis -
the correct way to tear down a hero3 camera by RageCams
dennis - Antwort
Hi,
Can anyone recommend which components i would need to replace if go pro got wet. When i switch it on its switches off and on constantly and also says no sd card.
Thanks
Newton - Antwort
Hi,
My gopro hero 3 black camera turns off and on.
Did you ever find out what the issue was?
Thanks!
Emil Burzo -
Got my camera filled with seawater a couple months back and just now decided to tear it apart (after being told gopro doesn't warranty water and buying a new one). I tried the rice trick as soon as it happened with no luck, all I did was use this guide to tear it apart, got a toothbrush and cleaned everything then again with isopropyl alcohol and so far it works! Thank you for a good write up!
Chris - Antwort
where can i buy the LCD screen?
josh - Antwort
Has anybody ever attempted to extend the ribbon attaching the camera lens and sensor away from the main camera body? Id love to hear anybody's comments if they have as its something ive been wanting to do for ages, can you mail me at rob@jdp.co.uk if you have any know how. Thanks, Rob
Rob Pilley - Antwort
Where is the Wi-fi antenna situated, would it be possible to somehow add an external antenna to it, maybe through a signal booster for greater range, for UAV FPV purposes?
Christos Oscar Kambiselis - Antwort
I had tried a lot of things after jumping with my GoPro Hero 3 Black Edition into the ocean with the wrong back door so it filled up with water right away. It died right on the spot and there was no way of turning it on. I took it apart after these directions and cleaned every single part. I put it back together and wola it works ;) thanks to you !
valdimar johannsson - Antwort
Hi,
i accidently put 12V on the usb in ! anyone same experience?
repairable?
thnx karl
Everaert - Antwort
Hi Everaert, I did the same thing providing power from FPV battery, puff of smoke and the smell, I was wondering if you found a fix?
Wayne -
no, you would need a new motherboard, ragecams carries them.
dennis -
can i send in my gopro and have you guys fix it because i have tried everything and nothing works. My gorpo hero 3 silver edition does not turn on at all.
alex - Antwort
I will like to trigger photo button of camera while in a RC flight. I imagine I can use a AUX signal from receiver so I can trigger a photo with Tx Control lever. Please tell me how to do this. Thanks.
alexcheve - Antwort
WORD OF CAUTION. I took apart my Hero 3 white. Didn't look the same as this one. The ribbon cable for the actual camera part was soldered to the board on mine.
Sean Cloughley - Antwort
Is it possible to get a replacement LCD screen if the cables snap?
Brooke - Antwort
Hi,
I currently have a GoPro Hero 3 and an AMKOV SJ5000 replica of GoPro. Usually I use the SJ Cam for hardcore use for motorcycle tours, mounted on foot pegs or mudguards and the GoPro for helmet cams job. So I was wondering if I can swap any hardware parts of SJ5000 cam with exisiting GoPro models? Like sensor swap? or lens? will that help me improve the SJ5000 cam in anyway. The SJ5000 is carbon copy of GoPro so I was thinking if the parts are interchangeable. Please delete this if it's not appropriate for this forum/thread.
-Z
San par - Antwort
STEP 15
Javixu - Antwort
Could I combine de device (the full black mount) of the Step 15 (sorry for my english!) from a Hero3 Silver with the rest of the thing of a Hero 3 black)??
Does it work like a full gopro 3 black o LCD screen doest not show black edition options?
Javixu - Antwort
hero 3 and 3+ are different. There is a ribbon cable from board to housing. can you tell me how to remove anyone.
Albert - Antwort
Does anyone know what the part number is for the connector on the flex PCB which connects to the image sensor?
Daniel S - Antwort
Hi Daniel - Any luck finding this part number?
Matt Whalen -
Hi. I think I just broke the ribbon pins from the housing to the motherboard: the white female receiver. Is there anything that can be done to connect the ribbon to have the buttons and wifi working ? Thank
Corbu Anonim - Antwort
My internal microphone is not working. It is recording only static noises. How can I fix it?
Please help me at zigrapa@gmail.com
Thanks
fzerillo - Antwort
Thanks for NOT mentioning, that the display cable can be easily ripped off cause the display is fixed to the outer plastic case by adhesives.. So better put a finger on the display when detaching the outer plastic case...
michaelhoeinghaus - Antwort
What does the AC3029 do? It's on the second picture in step 13 but no description
wcbruschi - Antwort
I was wondering the same thing.. Did you figure it out??
kanduryravi -
Thank you for the guide and the LCD part. My GoPro is now back to new after I crashed the drone and the LCD stopped displaying an image. Pretty easy fix.
dannystricker - Antwort
Hello,
First of all Thanks guys for all the hard work and for helping us save money! :-)
So now my question:
My wife pushed the usb to hard in and it broke off, but I manage to resolder it with a microscope and special tools, but unfortunately also that component with 4 leads right next to the microusb adapter fell off. I want to buy a new one and solder it on, but I have no clue as to what that is...
To me it seems a small high frequency transformer for the Video out? Could it be?
Where can I buy one? and what are the specifications? I know this is a hard question...
Derek Bernardon - Antwort
Bonjour, ma Gopro hero 3 ne charge plus car la prise USB de l'appareil s'est dessoudee, ou pourrais je trouver cet accessoire? Et si quelqu'un la déjà fais, est ce que c'est simple? Merci
Floriane - Antwort
Bonjour, il m'est impossible de charger ma Gopro, le mini port USB bouge, ou est ce que je pourrais trouver l'accessoire cassée et est ce que c'est facile à réparer? Merci
Floriane - Antwort
Hello there, this is more a question topic, i hace a hero 3 black dead, and a hero 3 silver with the external part of the lens crash, in your experienced opinion i can switch the part, they look tha same, but the cmos sensor obvioulsy if far more capable of the black, are the lens cover compatible?
ante lezama ricardo - Antwort
Hi, what is the function of the battery on the main board, the soldered one ?
sami maalouf - Antwort
Hi, what is the function of the battery on the main board ? the soldered one.
Hello, that small internal battery is for the internal clock, so you can take out the big battery and the internal clock will keep in sync so your pictires will be up to real date.
Diego -
Somebody knows how to replace the little internal clock and settings battery in the mainboard? My gopro got wet and after drying everything looks like the bathery short circuit and loose all the power. I tried to remove but looks to be soldered to the mainboard, is there any trick?
Diego -
The main board battery (used to save the clock settings) is number 414. The battery is spot welded to the base strip on the board (-), and the battery’s top (+) is spot welded to the + tab that’'s folded over the battery then connected to the board. There are fine connections from the + tab to the board. While the battery can be removed using a razor (very carefully), the + tab is glued to the board and soldered to the + leads of the board. If not “very” careful you can break the + tab away from the board. If your hero does not retain its clock settings, then that battery is dead.
DBrown -
Can you put a 3+ black mainboard in a normal 3 black camera since i can't find a normal 3 black board for replacement?
Cleveland2Steamerz - Antwort
Got a tips on water damage for hero3?
My case broke and the GoPro was under water for 5 sec now it was turn on.
Ronnie Tyrell - Antwort
Hi Jake..Your direction to dismantle were great..BUT..when I got down to motherboard,still can't get broken micro card out.! Any clues? Other than buy a new camera.!! Thanks..John W
John Willard - Antwort
Is the GoPro3 motherboard compatible with the GoPro3+ Black Edition's motherboard/main board?
lookitzserena - Antwort
Hi
My gopro hero 3+ won't turn on. I tried the multiple tutorials on internet with the removal of battery sd card etc...
I opened my gopro and voltage is arriving when connected to usb port, my gopro won't turn on though ....
anyone knows what it could be ?
Thanks !
marinekeiko - Antwort
Would the inners of a 3+ fit in the 3 body? Any help would be greatly appreciated! Thankyou!
dariusgibson - Antwort
I am on my 4th Hero 3 Black due to various failures. Multiple issues including color saturation, not turning on, vertical lines, juddering etc. They were all replaced under warranty - but left it too late to claim for a 5th and have had troubles with vertical lines and color saturation . Replaced my image sensor using these very informative instructions - seems to all be good. Thanks!
Hi,
Mine is not turning on too...
The front red led is also not turning on when power button is turned on and not that ng comes up in the display.
What would be the problem?
I thought it was only frozen but it seems that it is a more complex problem to resolve.
Cheers,
Ricardo G.
Ricardo Gouveia - Antwort
It’s always good to see a quick set of straight forward instructions so I know what I can & shouldn’t pry, to avoid unnecessary damage.
Bob Mullins - Antwort
Wow This is amazing,,,,You have shared awesome stuff in your blog.
Read review Unlocker Software
unlocker software - Antwort
nice this post thanks for sharing Unlocker download
Dangdut Tube - Antwort
Great article to know more review Google Chrome 2019 . Thanks For admin
jonartha petra - Antwort
Thank you for this article......to download Keyboard 2018 APK latest version.....you can visit this site Go Keyboard 2018 and also Go Keyboard Download
Great post!!
WHat i have to say about these days Download Mozilla Firefox 32bit has the best for download browser
browser download - Antwort
Smadav 2019 PC/Laptop/notebook Windows system 32bit/64bit is available for You. Smadav 2019 version Offline Installer after download that can update/install without need connection the internet again. Download and install Smadav 2019 Free
softalead - Antwort
Softalead is the site for Free Software and Apps to Download the Latest Version.
richardsimonse - Antwort
REaly this is an nice content. If need education content you may visit here
SSC Result 2019 BD Online - Antwort
so my Gopro was plugged into a 12v power source that blew my hero3 white edition up and while trying to remove the cover to see if I wanted to try and repair this myself I broke the ribbon on the LCD screen.
what parts would I need to repair this Gopro if its even worth fixing
Dave - Antwort
is this thermal paste on the chipsets ? If its thermal paste can I use a thermal paste of Cooler master mastergel maker nano with 11W/Kw thermal condactivity? Or should I use a special thermal paste for gopro hero 3+ chipsets ? Which thermal paste should I use ?
MAE Production - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 22
Letzte 30 Tage: 137
Insgesamt: 346,687
