Zum Hauptinhalt wechseln
Samsung Galaxy S8 Plus Screen Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Koreanisch
Schritt 16 übersetzen
Schritt 16
Samsung Galaxy S8 Plus Screen Replacement: Schritt 0, Bild 1 von 2 Samsung Galaxy S8 Plus Screen Replacement: Schritt 0, Bild 2 von 2
  • Remove the display.
  • Follow this link for a detailed screen adhesive application guide.
  • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, while taking special care to remove any small glass fragments.
  • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter. Swipe in one direction only, not back and forth.
  • This helps remove any remaining adhesive residue and preps the surface for the new adhesive.
  • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
  • The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
Hier Übersetzung einfügen
