Zum Hauptinhalt wechseln
Huawei Honor 9 Motherboard Assembly Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch und 3 weitere Mitwirkende
Zuletzt aktualisiert am May 7, 2024
30 - 50 Minuten
Mittel
Use this guide to remove the motherboard assembly in the Huawei Honor 9.
You’ll need replacement adhesive to reattach components when reassembling the device.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Huawei Honor 9 Motherboard Assembly Replacement, Remove the Rear Glass: Schritt 1, Bild 1 von 1
    • Switch off your phone.
    • Heat an iOpener and apply it to the back of the phone for around two minutes. This will help soften the adhesive securing the rear glass.
    • You might need to reheat and reapply the iOpener several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 2, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 2, Bild 2 von 2
    • Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
    • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift the rear glass with the suction cup to create a gap between the glass and the frame.
    • Insert an opening pick into the gap.
    • Don't attempt to insert a pick between the back glass and the frame before creating a gap. The glass is covered with foil from the inside, and by not creating a gap, you risk inserting the pick between the glass and the foil instead, which would permanently damage the foil and ruin the solid color of the back panel.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  3. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 3, Bild 1 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 3, Bild 2 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 3, Bild 3 von 3
    • Slide the opening pick to the bottom right corner.
    • Insert a second opening pick and slide it to the bottom left corner.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 4, Bild 1 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 4, Bild 2 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 4, Bild 3 von 3
    • Insert a third opening pick at the bottom left corner.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the Huawei Honor 9 to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 5, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 5, Bild 2 von 2
    • If the adhesive gets hard to cut it is likely too cold. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the rear glass.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 6, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 6, Bild 2 von 2
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 7, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Tesa 61395 Tape
    $5.99
    • Carefully lift the rear glass and remove it.
    • Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Huawei Honor 9 Motherboard Assembly Replacement, Remove the Motherboard Shield: Schritt 8, Bild 1 von 1
    • Remove the three Phillips #00 screws (3.45 mm length).
    • Remove the five Phillips #00 screws (2.9 mm length).
  9. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 9, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 9, Bild 2 von 2
    • Carefully peel up the black thermal foil and remove it completely.
    • This foil is very thin and brittle and may rip easily.
    • Remove the Phillips #00 screw that is located underneath the thermal foil at the bottom center of the motherboard.
  10. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 10, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 10, Bild 2 von 2
    • Slide an opening pick under the right side of the motherboard shield.
    • Twist the opening pick sideways to release the clips that hold the shield in place.
    • Repeat the previous process and work your way around the motherboard shield until it pops out.
  11. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 11, Bild 1 von 1
    • Remove the motherboard shield.
  12. Huawei Honor 9 Motherboard Assembly Replacement, Disconnect the Battery: Schritt 12, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement, Disconnect the Battery: Schritt 12, Bild 2 von 2
    • Use a spudger to pry up and disconnect the battery flex cable.
  13. Huawei Honor 9 Motherboard Assembly Replacement, Remove the Motherboard Assembly: Schritt 13, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement, Remove the Motherboard Assembly: Schritt 13, Bild 2 von 2
    • Remove the SIM card tray.
  14. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 14, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 14, Bild 2 von 2
    • Use a pair of tweezers to pry up and disconnect the antenna coax cable located next to the battery connector.
  15. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 15, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 15, Bild 2 von 2
    • Use a spudger to pry up and disconnect the interconnect flex cable.
  16. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 16, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 16, Bild 2 von 2
    • Use a spudger to pry up and disconnect the display flex cable.
  17. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 17, Bild 1 von 2 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 17, Bild 2 von 2
    • Use a spudger to pry up and disconnect the power and volume button flex cable.
  18. Huawei Honor 9 Motherboard Assembly Replacement: Schritt 18, Bild 1 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 18, Bild 2 von 3 Huawei Honor 9 Motherboard Assembly Replacement: Schritt 18, Bild 3 von 3
    • Insert a spudger in the gap between the battery and the motherboard.
    • Carefully pry up the motherboard until you can get a good grip.
    • Make sure the previously unplugged connectors are out of the way and avoid damaging any close components while lifting the motherboard.
    • Remove the motherboard assembly.
Abschluss
229.724 Reputation
682 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
19.481 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 1,550
