Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement
Tyler Schrock
Tyler Schrock und eine weitere beteiligte Person
Zuletzt aktualisiert am December 29, 2020
3 Minuten
Leicht
Anleitung eines Community-Mitglieds
This guide will show you how to remove the back panel from your Lenovo IdeaPad Flex 5 14ARE05.
Was du brauchst
Werkzeuge
Mehr anzeigen …
  1. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the five 8 mm screws using a T5 Torx Screwdriver.
    • Remove the four 5 mm screws using a T5 Torx Screwdriver.
  2. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: Schritt 2, Bild 3 von 3
    • Use a small suction cup to pull open the back case at the two hinge cutouts.
    • Gently, use the plastic opening tool around the edges of the laptop to pry up the rest of the back panel.
  3. Lenovo IdeaPad Flex 5 14ARE05 Back Panel Replacement: Schritt 3, Bild 1 von 1
    • Once all the clips have been disengaged, lift off the back cover.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Tyler Schrock
458 Reputation
2 Anleitungen geschrieben
3 Kommentare
This guide has been very helpful but I have a problem with missing screws 3 have fallen out now. and I see the guide doesn't list any parts so where could I go to find the screws?
Timothy Alper - Antwort
Same issue (on a Lenovo ChromeBook Flex 5 ‎82B80006UX). I'm guessing a M2 or M2.5 x 5mm & 8mm. I'm ordering some assorted screws & I'll post if any seem to really hit the size.
BenBen7 -
Hi. Why do some laptops have some kind of a sheet of paper blocking some part of their bottom vents, leaving a hole only for the fan intake? Is it safe to remove the paper?
Haris Sahlan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 10
Letzte 30 Tage: 99
Insgesamt: 2,912
