Zum Hauptinhalt wechseln
iPad 9 LTE Button Control Cable Replacement
Was du brauchst
  1. iPad 9  LTE Button Control Cable Replacement, Heat the left edge: Schritt 1, Bild 1 von 1
    • Power down your iPad before beginning the repair.
    • Heat an iOpener and apply it to the left edge of the iPad for two minutes.
    Frag FixBot
    Kommentar hinzufügen
  2. iPad 9  LTE Button Control Cable Replacement, Screen removal information: Schritt 2, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Screen removal information: Schritt 2, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Screen removal information: Schritt 2, Bild 3 von 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Ambient light sensors
    • Antennas
    • Display cables
    Frag FixBot
  3. iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: Schritt 3, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: Schritt 3, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Anti-Clamp instructions: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
    Frag FixBot
  4. iPad 9  LTE Button Control Cable Replacement: Schritt 4, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 4, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 4, Bild 3 von 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Frag FixBot
  5. iPad 9  LTE Button Control Cable Replacement: Schritt 5, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 5, Bild 2 von 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
    Frag FixBot
  6. iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: Schritt 6, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: Schritt 6, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Insert an opening pick: Schritt 6, Bild 3 von 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
    Frag FixBot
  7. iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: Schritt 7, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: Schritt 7, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the left adhesive: Schritt 7, Bild 3 von 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the iPad to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
    Frag FixBot
  8. iPad 9  LTE Button Control Cable Replacement: Schritt 8, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 8, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 8, Bild 3 von 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
    Frag FixBot
  9. iPad 9  LTE Button Control Cable Replacement: Schritt 9, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 9, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 9, Bild 3 von 3
    • Slide the first opening pick towards to top-left corner of the iPad to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
    Frag FixBot
  10. iPad 9  LTE Button Control Cable Replacement, Heat the top edge: Schritt 10, Bild 1 von 1
    • Heat an iOpener and apply it to the top edge of the iPad for two minutes.
    Frag FixBot
  11. iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: Schritt 11, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: Schritt 11, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top left adhesive: Schritt 11, Bild 3 von 3
    • Rotate the pick around the top-left corner of the iPad to separate the adhesive.
    • Only insert the pick up to 7 mm to avoid damaging the ambient light sensor.
    Frag FixBot
  12. iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: Schritt 12, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: Schritt 12, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top adhesive: Schritt 12, Bild 3 von 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
    Frag FixBot
  13. iPad 9  LTE Button Control Cable Replacement: Schritt 13, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 13, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 13, Bild 3 von 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
    Frag FixBot
  14. iPad 9  LTE Button Control Cable Replacement: Schritt 14, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 14, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 14, Bild 3 von 3
    • Re-insert the pick and slide it towards the top-right corner of the iPad to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
    Frag FixBot
  15. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: Schritt 15, Bild 1 von 1
    • Heat an iOpener and apply it to the right edge of the iPad for two minutes.
    Frag FixBot
  16. iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: Schritt 16, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: Schritt 16, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the top right adhesive: Schritt 16, Bild 3 von 3
    • Rotate the pick around the top-right corner of the iPad to separate the adhesive.
    • Only insert the pick up to 4 mm to avoid damaging the ambient light sensor.
    Frag FixBot
  17. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 17, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 17, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 17, Bild 3 von 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
    Frag FixBot
  18. iPad 9  LTE Button Control Cable Replacement, Heat the bottom edge: Schritt 18, Bild 1 von 1
    • Heat an iOpener and apply it to the bottom edge of the iPad for two minutes.
    Frag FixBot
  19. iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: Schritt 19, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: Schritt 19, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the bottom left adhesive: Schritt 19, Bild 3 von 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • The third image shows the bottom-left antenna underneath the digitizer.
    • Leave the pick in the corner before moving to the next step.
    Frag FixBot
  20. iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: Schritt 20, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: Schritt 20, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the bottom adhesive: Schritt 20, Bild 3 von 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
    Frag FixBot
  21. iPad 9  LTE Button Control Cable Replacement: Schritt 21, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 21, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 21, Bild 3 von 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    Frag FixBot
  22. iPad 9  LTE Button Control Cable Replacement: Schritt 22, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 22, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 22, Bild 3 von 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
    Frag FixBot
  23. iPad 9  LTE Button Control Cable Replacement, Heat the right edge: Schritt 23, Bild 1 von 1
    Frag FixBot
  24. iPad 9  LTE Button Control Cable Replacement: Schritt 24, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 24, Bild 2 von 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
    Frag FixBot
  25. iPad 9  LTE Button Control Cable Replacement: Schritt 25, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 25, Bild 2 von 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
    Frag FixBot
  26. iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 26, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 26, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Separate the right adhesive: Schritt 26, Bild 3 von 3
    Frag FixBot
  27. iPad 9  LTE Button Control Cable Replacement: Schritt 27, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 27, Bild 2 von 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the iPad. Make sure they are folded properly underneath the LCD screen to prevent any damage.
    Frag FixBot
  28. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: Schritt 28, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: Schritt 28, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: Schritt 28, Bild 3 von 3
    • Use tweezers, or your fingers, to remove any tape covering the LCD screws.
    Frag FixBot
  29. iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: Schritt 29, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Unfasten the LCD screen: Schritt 29, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 4.2 mm screws securing the LCD screen.
    Frag FixBot
  30. iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: Schritt 30, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Separate the LCD's adhesive: Schritt 30, Bild 2 von 2
    • The LCD is lightly adhered to the frame.
    • Insert a spudger between the frame and the top-right portion of the LCD.
    • Pry slowly with the spudger to separate the adhesive.
    Frag FixBot
  31. iPad 9  LTE Button Control Cable Replacement: Schritt 31, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 31, Bild 2 von 2
    • Repeat the previous step for the top-left portion of the LCD.
    Frag FixBot
  32. iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: Schritt 32, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: Schritt 32, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Reposition the LCD screen: Schritt 32, Bild 3 von 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by a flex cable.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD on a clean, soft, lint-free surface to allow access to the display cables.
    Frag FixBot
  33. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: Schritt 33, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: Schritt 33, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
    Frag FixBot
  34. iPad 9  LTE Button Control Cable Replacement, Battery connector information: Schritt 34, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Battery connector information: Schritt 34, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Battery connector information: Schritt 34, Bild 3 von 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
    Frag FixBot
  35. iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: Schritt 35, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: Schritt 35, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Disconnect the battery: Schritt 35, Bild 3 von 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
    Frag FixBot
  36. iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: Schritt 36, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Unfasten the display cable bracket: Schritt 36, Bild 2 von 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
    Frag FixBot
  37. iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: Schritt 37, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Remove the display cable bracket: Schritt 37, Bild 2 von 2
    • Remove the display cable bracket.
    Frag FixBot
  38. iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: Schritt 38, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the LCD: Schritt 38, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the LCD cable press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Frag FixBot
  39. iPad 9  LTE Button Control Cable Replacement, Remove the LCD: Schritt 39, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Remove the LCD: Schritt 39, Bild 2 von 2
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
    Frag FixBot
  40. iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: Schritt 40, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the home button: Schritt 40, Bild 2 von 2
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
    Frag FixBot
  41. iPad 9  LTE Button Control Cable Replacement: Schritt 41, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 41, Bild 2 von 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
    Frag FixBot
  42. iPad 9  LTE Button Control Cable Replacement: Schritt 42, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 42, Bild 2 von 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
    Frag FixBot
  43. iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: Schritt 43, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: Schritt 43, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Disconnect the display cables: Schritt 43, Bild 3 von 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
    Frag FixBot
  44. iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: Schritt 44, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: Schritt 44, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the buffer block: Schritt 44, Bild 3 von 3
    • Use the flat end of a spudger to pry up the buffer block near the bottom-right corner of the iPad.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the buffer block.
    Frag FixBot
  45. iPad 9  LTE Button Control Cable Replacement: Schritt 45, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 45, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 45, Bild 3 von 3
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
    Frag FixBot
  46. iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: Schritt 46, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: Schritt 46, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the front panel assembly: Schritt 46, Bild 3 von 3
    Polyimide Tape
    $9.95
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
    Frag FixBot
  47. iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: Schritt 47, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Remove the upper bracket tape: Schritt 47, Bild 2 von 2
    • Carefully peel the LCD buffer tape from the upper component bracket.
    Frag FixBot
  48. iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: Schritt 48, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Unfasten the upper component bracket: Schritt 48, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the five screws securing the the upper component bracket:
    • Three 1.4 mm-long screws
    • Two 1.9 mm-long screws
    Frag FixBot
  49. iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: Schritt 49, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Remove the upper component bracket: Schritt 49, Bild 2 von 2
    • Use the pointed end of a spudger to lift up the upper component bracket until you can grip it with your fingers.
    Frag FixBot
  50. iPad 9  LTE Button Control Cable Replacement: Schritt 50, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 50, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 50, Bild 3 von 3
    • Use your fingers to peel the upper component bracket away from the tape.
    • Remove the upper component bracket.
    Frag FixBot
  51. iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: Schritt 51, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the rear camera: Schritt 51, Bild 2 von 2
    • Use the flat end of a spudger to pry up and disconnect the rear camera press connector.
    Frag FixBot
  52. iPad 9  LTE Button Control Cable Replacement, Heat the rear camera: Schritt 52, Bild 1 von 1
    • Heat an iOpener and apply it to the rear camera for thirty seconds.
    Frag FixBot
  53. iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: Schritt 53, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: Schritt 53, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the rear camera: Schritt 53, Bild 3 von 3
    • Use a spudger to pry the rear camera out of the frame.
    • Use tweezers, or your fingers, to remove the rear camera.
    Frag FixBot
  54. iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: Schritt 54, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the right ambient light sensor: Schritt 54, Bild 2 von 2
    • The right ambient light sensor is lightly adhered to the frame.
    • Use tweezers, or your fingers, to remove the sensor.
    Frag FixBot
  55. iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: Schritt 55, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Reposition the right ambient light sensor: Schritt 55, Bild 2 von 2
    • Peel the right ambient light sensor towards the right edge of the device, enough to access the screw behind it.
    Frag FixBot
  56. iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: Schritt 56, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Unfasten the power button bracket: Schritt 56, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 2.3 mm-long screws securing the lock button bracket.
    Frag FixBot
  57. iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: Schritt 57, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Reposition the button control cable: Schritt 57, Bild 2 von 2
    • Use your fingers to pull the power button bracket out of its recess.
    Frag FixBot
  58. iPad 9  LTE Button Control Cable Replacement: Schritt 58, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 58, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 58, Bild 3 von 3
    • The button control cable is lightly adhered to the side of the volume button bracket.
    • Peel the button control cable away from the volume button bracket.
    Frag FixBot
  59. iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: Schritt 59, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Unfasten the volume button bracket: Schritt 59, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 2.2 mm-long screws securing the volume button bracket to the rear case.
    Frag FixBot
  60. iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: Schritt 60, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: Schritt 60, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the volume button bracket: Schritt 60, Bild 3 von 3
    • Use tweezers, or your fingers, to pull the volume button bracket away from the device's edge.
    • Remove the volume button bracket.
    Frag FixBot
  61. iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: Schritt 61, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Disconnect the button control cable: Schritt 61, Bild 2 von 2
    • Peel off any tape covering the button control cable ZIF connector.
    Frag FixBot
  62. iPad 9  LTE Button Control Cable Replacement: Schritt 62, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 62, Bild 2 von 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the button control cable's ZIF connector.
    Frag FixBot
  63. iPad 9  LTE Button Control Cable Replacement: Schritt 63, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement: Schritt 63, Bild 2 von 2
    • Use a pair of tweezers to carefully pull the button control cable straight out of the ZIF connector.
    Frag FixBot
  64. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: Schritt 64, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: Schritt 64, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: Schritt 64, Bild 3 von 3
    • Use the flat end of a spudger to push the volume buttons out of their slots in the rear case.
    Frag FixBot
  65. iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: Schritt 65, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Remove the button control cable: Schritt 65, Bild 2 von 2
    • Remove the button control cable.
    • The lock button will become loose once the button control cable is removed.
    • Upon reassembly, remember to set the power button back into the its slot.
    Frag FixBot
  66. iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: Schritt 66, Bild 1 von 2 iPad 9  LTE Button Control Cable Replacement, Loosen the adhesive: Schritt 66, Bild 2 von 2
    • Heat an iOpener and apply it to the button control cable for thirty seconds.
    Frag FixBot
  67. iPad 9  LTE Button Control Cable Replacement, Remove the buttons: Schritt 67, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: Schritt 67, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the buttons: Schritt 67, Bild 3 von 3
    • Use a pair of tweezers to grip the upper volume button.
    • Insert an opening pick between the volume control cable and the upper volume button.
    • Peel the volume control cable off of the upper volume button.
    Frag FixBot
  68. iPad 9  LTE Button Control Cable Replacement: Schritt 68, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 68, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement: Schritt 68, Bild 3 von 3
    • Repeat the same process to peel the volume control cable off of the lower volume button.
    Frag FixBot
  69. iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: Schritt 69, Bild 1 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: Schritt 69, Bild 2 von 3 iPad 9  LTE Button Control Cable Replacement, Remove the power button bracket: Schritt 69, Bild 3 von 3
    Tesa 61395 Tape
    $8.95
    • Use a pair of tweezers to grip the power button bracket.
    • Insert a halberd spudger or opening pick between the power button bracket and the button control cable.
    • Peel the button control cable up and off of the pegs on the power button bracket.
    • Upon reassembly, apply Tesa tape to reattach the volume buttons and lock button bracket to the button control cable.
    Frag FixBot
  70. iPad 9  LTE Button Control Cable Replacement: Schritt 70, Bild 1 von 1
    • Only the button control cable remains.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 9 Answers community for help.
Alex Diaz-Kokaisl
238.682 Reputation
1.171 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.864 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 37
Insgesamt: 972
