Zum Hauptinhalt wechseln
iPhone Battery Adhesive Strips Replacement
Was du brauchst
Einführungsvideo
  1. iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: Schritt 1, Bild 1 von 3 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: Schritt 1, Bild 2 von 3 iPhone Battery Adhesive Strips Replacement, iPhone Battery Adhesive Strips: Schritt 1, Bild 3 von 3
    • If your new battery came with adhesive strips already stuck on, skip to Step 7.
    • Otherwise: If present, remove the small plastic film(s) covering the flat ends of the adhesive strips.
  2. iPhone Battery Adhesive Strips Replacement: Schritt 2, Bild 1 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 2, Bild 2 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 2, Bild 3 von 3
    • With the battery facing up (battery connector on the right), carefully align the exposed portion of the adhesive strips along the lower edge of the front of the battery, and press them gently into place.
    • Take care to line up the strips correctly the first time. Once they adhere to the battery, they can't be removed and reused—you'll have to start over with fresh strips.
  3. iPhone Battery Adhesive Strips Replacement: Schritt 3, Bild 1 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 3, Bild 2 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 3, Bild 3 von 3
    • Place the battery face down on a flat surface.
    • Starting at the pointed end of the adhesive strips, peel off the large blue film covering the strips.
    • The blue film sometimes has a defect that prevents it from peeling off, and the strips have to be discarded and replaced.
    • If this happens to you and you got your strips from iFixit, contact us here and we'll send you a replacement on the double.
    • In the meantime, you can temporarily reassemble your iPhone with a bit of double-sided tape to hold the battery.
  4. iPhone Battery Adhesive Strips Replacement: Schritt 4, Bild 1 von 2 iPhone Battery Adhesive Strips Replacement: Schritt 4, Bild 2 von 2
    • Using your fingertip, gently roll the adhesive strips over the bottom edge of the battery, toward the back.
    • Don't pull or stretch the strips when applying them.
  5. iPhone Battery Adhesive Strips Replacement: Schritt 5, Bild 1 von 2 iPhone Battery Adhesive Strips Replacement: Schritt 5, Bild 2 von 2
    • Lay the strips down flat and let them stick to the back of the battery.
  6. iPhone Battery Adhesive Strips Replacement: Schritt 6, Bild 1 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 6, Bild 2 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 6, Bild 3 von 3
    • Use your fingers or a cloth to press the strips firmly into place all along the back of the battery.
  7. iPhone Battery Adhesive Strips Replacement: Schritt 7, Bild 1 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 7, Bild 2 von 3 iPhone Battery Adhesive Strips Replacement: Schritt 7, Bild 3 von 3
    • Carefully peel away the remaining piece of film, fully exposing the adhesive strips.
  8. iPhone Battery Adhesive Strips Replacement: Schritt 8, Bild 1 von 2 iPhone Battery Adhesive Strips Replacement: Schritt 8, Bild 2 von 2
    • Without sticking the battery down, lower its connector into the iPhone and align it to its socket on the logic board.
    • Connect the battery.
  9. iPhone Battery Adhesive Strips Replacement: Schritt 9, Bild 1 von 2 iPhone Battery Adhesive Strips Replacement: Schritt 9, Bild 2 von 2
    • Carefully position the battery and set it into the iPhone.
    • If possible, try to leave a little space around the battery on the bottom edge and along the left side. This will make it easier to extract the adhesive strips should you need to replace the battery again in the future.
  10. iPhone Battery Adhesive Strips Replacement: Schritt 10, Bild 1 von 2 iPhone Battery Adhesive Strips Replacement: Schritt 10, Bild 2 von 2
    • When the battery is correctly positioned, lay it down in the iPhone and press it firmly into place, allowing the adhesive strips to stick to the rear case.
  11. iPhone Battery Adhesive Strips Replacement: Schritt 11, Bild 1 von 1
    • Be sure to disconnect the battery again before reassembling your iPhone.
    • Working on your phone with the battery connected can destroy sensitive components.
Abschluss
To reassemble your iPhone, return to the guide you used to remove the battery and follow the steps in reverse order.
Remember to take your old battery to an R2 or e-Stewards certified recycler.
1618 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeff Suovanen
428.113 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
68 Kommentare
I had to read these directions thoroughly three times before proceeding as I didn't want to screw it up on the adhesive. Went slow and it worked just fine
patrick knaggs - Antwort
I would say jus watch out as you go from step 4 to step 5 - the white adhesive can become slightly detached from the backing as you push it onto the edge of the battery and then around to the back side. Extreme care here! Very good guide and equipment. Galaxy class!
Steve Cottrell - Antwort
All was good, aside from the adhesive bunched up when I removed the blue backing and it started to separate from the pink backing. I had to just gingerly make sure it was all straight and kept steady like a heart surgeon until I had it smoothed down as best as possible. It all went well, but I was worried I'd end up with a big stuck ball of white adhesive in the middle of the battery plate, making it all uneven and stupid looking.
DiscoDan74 - Antwort
What happens if I use a different adhesive than this one?
gleeglee217 - Antwort
The iPhone adhesive strips we sell (and the original Apple ones) are special since they have very strong adhesion, but they can be removed easily by pulling on the tabs on the lower edge of the battery. People have had success with our 3M double-sided sticky tape (aka sticker tape), but standard plastic double-sided tape may not have enough strength to hold the battery in place. If you want the strongest adhesive possible, you should use iPhone adhesive strips mentioned above, but if your phone isn't subject to lots of movement, you could get by with some sticker tape.
Evan Noronha -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 41
Letzte 7 Tage: 455
Letzte 30 Tage: 1,260
Insgesamt: 507,740
