Zum Hauptinhalt wechseln
Razer Blade 15" (2018) Heatsink Replacement
Clay Eickemeyer
Clay Eickemeyer und eine weitere beteiligte Person
Zuletzt aktualisiert am May 7, 2024
30 Minuten - 1 Stunde
Mittel
Use this guide to remove or replace the heatsink in your Razer Blade 15" (2018).
You'll need replacement thermal pads to complete this repair.
Note: This guide refers to the left and right fans relative to the side of the laptop they're on while the screen is open and facing you, and not while the laptop is open and upside-down.
Was du brauchst
Werkzeuge
Mehr anzeigen …
iFixit erhält eine Provision, wenn du über diese Links etwas kaufst.
  1. Razer Blade 15" (2018) Heatsink Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 2 Razer Blade 15" (2018) Heatsink Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 2 von 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables, fully shut down your laptop, and close the lid.
  2. Razer Blade 15" (2018) Heatsink Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 1
    • Rotate your laptop so the screen hinge is farthest from you.
    • Use a Torx T5 driver to remove the ten 3.8 mm-long screws securing the back cover.
  3. Razer Blade 15" (2018) Heatsink Replacement, Insert an opening pick: Schritt 3, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Insert an opening pick: Schritt 3, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Insert an opening pick: Schritt 3, Bild 3 von 3
    • Depending on the age and condition of your laptop, the back cover may come off sooner than this guide instructs. If the cover feels loose, remove it at any time.
    • Apply a suction handle to the right edge of the back cover, between the middle screws and the screws closest to you.
    • Pull up on the suction handle to create a small gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  4. Razer Blade 15" (2018) Heatsink Replacement, Angle the opening pick: Schritt 4, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Angle the opening pick: Schritt 4, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Angle the opening pick: Schritt 4, Bild 3 von 3
    • Angle your opening pick upward, away from the frame. Keep it angled upward as long as it's between the back cover and the frame.
    • Insert your pick up to 10 mm (0.4 in) deep.
  5. Razer Blade 15" (2018) Heatsink Replacement, Free the bottom right corner: Schritt 5, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Free the bottom right corner: Schritt 5, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Free the bottom right corner: Schritt 5, Bild 3 von 3
    • Slide your opening pick around the bottom right corner of the back cover to free it from the frame.
  6. Razer Blade 15" (2018) Heatsink Replacement, Free the front edge: Schritt 6, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Free the front edge: Schritt 6, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Free the front edge: Schritt 6, Bild 3 von 3
    • Slide your opening pick along the front edge and around the front left corner of the back cover to free it from the frame.
  7. Razer Blade 15" (2018) Heatsink Replacement, Remove the back cover: Schritt 7, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Remove the back cover: Schritt 7, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Remove the back cover: Schritt 7, Bild 3 von 3
    • Remove the back cover.
    • Lay the back cover down on its rubber feet to avoid damaging the gray thermal pads on its underside.
  8. Razer Blade 15" (2018) Heatsink Replacement, Soften the battery cable tape adhesive: Schritt 8, Bild 1 von 2 Razer Blade 15" (2018) Heatsink Replacement, Soften the battery cable tape adhesive: Schritt 8, Bild 2 von 2
    • Apply a heated iOpener to the battery cable tape for one minute.
    • You can also use a hair dryer—but be careful, as overheating the battery may damage it or create a fire hazard.
  9. Razer Blade 15" (2018) Heatsink Replacement, Peel up the battery cable tape: Schritt 9, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Peel up the battery cable tape: Schritt 9, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Peel up the battery cable tape: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Be careful not to damage the battery with your tool.
    • Use blunt nose tweezers or your fingers to peel the battery cable tape away from the cable.
  10. Razer Blade 15" (2018) Heatsink Replacement, Disconnect the battery: Schritt 10, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Disconnect the battery: Schritt 10, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Disconnect the battery: Schritt 10, Bild 3 von 3
    • Use the point of a spudger to press on alternating sides of the battery connector and walk it out of its socket.
  11. Razer Blade 15" (2018) Heatsink Replacement, Remove the screw covers: Schritt 11, Bild 1 von 2 Razer Blade 15" (2018) Heatsink Replacement, Remove the screw covers: Schritt 11, Bild 2 von 2
    • Use tweezers or your fingers to peel and remove the six screw covers from the heatsink.
  12. Razer Blade 15" (2018) Heatsink Replacement, Unfasten the heatsink: Schritt 12, Bild 1 von 2 Razer Blade 15" (2018) Heatsink Replacement, Unfasten the heatsink: Schritt 12, Bild 2 von 2
    • Use your Phillips screwdriver to remove the two 4.7 mm screws securing the top left and bottom left edges of the heatsink.
    • Use your Phillips screwdriver to fully loosen the eight captive screws securing the center of the heatsink.
    • These screws aren't designed to come out. However, if one does come out, set it and its spring aside.
    • During reassembly, tighten these screws in an X-pattern to evenly compress the thermal paste.
  13. Razer Blade 15" (2018) Heatsink Replacement, Pry up the heatsink: Schritt 13, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Pry up the heatsink: Schritt 13, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Pry up the heatsink: Schritt 13, Bild 3 von 3
    • Don't pry against the motherboard or any cables.
    • Use the flat end of your spudger to pry up the heatsink until it separates from the motherboard at the following locations:
    • Between the bottom left corner of the left metal plate and the SSD
    • The right edge of the right metal plate
    • The top edge of the right metal plate, above the copper pipes
  14. Razer Blade 15" (2018) Heatsink Replacement, Remove the heatsink: Schritt 14, Bild 1 von 3 Razer Blade 15" (2018) Heatsink Replacement, Remove the heatsink: Schritt 14, Bild 2 von 3 Razer Blade 15" (2018) Heatsink Replacement, Remove the heatsink: Schritt 14, Bild 3 von 3
    • Lift the right edge of the heatsink from the motherboard.
    • Slide the heatsink to the right so the left screw tab slides out from under the screen cable.
    • Remove the heatsink.
    • During reassembly:
    • Inspect the thermal pads for damage. Apply new pads if any tear or deform too much.
    • Follow this guide to clean and reapply thermal paste to the CPU and GPU.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Clay Eickemeyer
82.084 Reputation
455 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Staff
9 Mitglieder
11.442 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 682
